Bios Lenovo V15-IGL
  • CITA2007
    • Dec 2024
    • 10
    • Italia
    If I want I can do it but I have no problem reading and writing the chip I just need the right file.
    • hardware1
      • Sep 2021
      • 2939
      • N/A
      Here is your new file, it's a virgin BIOS from Lenovo with your DMI.
      This file should works fine.
      all donations are welcome,
      • CITA2007
        • Dec 2024
        • 10
        • Italia
        I'll try it though, the bios file that I download from lenovo is dvcn34 not 28
        • CITA2007
          • Dec 2024
          • 10
          • Italia
          im using neo programmer it doesnt work it sais ic not responding ps im not using a 1.8 volt adapter ,the chip works it has 1.8volt from the battery
          • hardware1
            • Sep 2021
            • 2939
            • N/A
            34 and 28 is just the version so don't worry.
            You have to use a 1.8v adapter if your chip needs 1.8v supply for sure. Also you have to choose verify after programming the chip to be sure that the written file is identical with your opened file.
            • CITA2007
              • Dec 2024
              • 10
              • Italia
              #26
              I bought a 1.8V adapter, but when I try to do detect or write, it says:
              Verify memory...
              Verification error on address: 00000000
              Execution time: 00:00:00.
              I'm using the clip, and I don't think there are any connection issues. I'm using AsProgrammer, but I have problems even with other software, and the detect function doesn't work. However, I can read and verify, it lets me do that. Any suggestions?
              • Seb RS
                • Sep 2024
                • 9
                • france
                #27
                Could you help me with this bios please.​
                Lenovo V15-IGL
                Model : 82C3
                S/N : PF39C5CJ
                MTM : 82C3001WFR
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11840
                  #28
                  Lenovo V15-IGL
                  Model : 82C3
                  S/N : PF39C5CJ
                  MTM : 82C3001WFR
                  V15-IGL Laptop (Lenovo) - Type 82C3
                  • Seb RS
                    • Sep 2024
                    • 9
                    • france
                    #29
                    Hello
                    Thank you!
                    But it's not working.
                    I'm having a problem with this EEPROM
                    Winbond 25Q64JWSIQ
                    It's the third LENOVO laptop with this chip that I've tried to write and it fails.
                    There are some hexadecimal blocks that are different after erasing/writing/checking.
                    I use a EZP2023+ programmer
                    He recognizes the chip and reads it.
                    I've tried different write speeds, it's always the same blocks in error.
                    I don't have this problem with other laptop models
                    Do you have any idea where the problem may come from?​
                    • peste
                      • Dec 2016
                      • 12887
                      • ROMANIA
                      #30
                      Hello
                      Thank you!
                      Winbond 25Q64JWSIQ
                      The bios chip must be unsoldered from the board before writing or reading..
                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                      solder wires between the programmer and the bios chip..
                      here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                      • Khoja
                        • Jul 2016
                        • 32
                        • Узбекистан
                        #31
                        I have a Lenovo V15-IGL laptop that originally had a BIOS password. I wasn’t able to reset it, so I flashed the BIOS using this file:
                        👉 https://www.badcaps.net/filedata/fetch?id=2082788
                        After flashing, the BIOS password issue is gone, but now:
                        • The serial number and other system info appear incorrect or missing.
                        • It's asking for an HDD password, and I can’t access the drive.
                        Laptop Details:
                        • Model: Lenovo V15-IGL
                        • Model Name: 82C3
                        • Serial Number: PF386JZ
                        • Motherboard: REV: 1.0 NM-D201 GV452/GV552 (2019-12-27)
                        HDD Details:
                        • Brand: Seagate
                        • Model: ST1000LM035 (1TB)
                        • Serial Number: WKPT1BC6
                        I’ve uploaded the backup file — could the password or system info be inside it?
                        Any help or advice would be greatly appreciated.
                        Thanks in advance!
                        • peste
                          peste commented
                          Editing a comment
                          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                          Don't post pictures unless asked...
                      • peste
                        • Dec 2016
                        • 12887
                        • ROMANIA
                        #32
                        try.....
                        for hdd password...change hdd
                        • Terz05
                          • Aug 2025
                          • 3
                          Hello, I have the old bin file with the correct DMI data and a second DMI that corresponds to the most recent one on the manufacturer's website. However, I can't copy the DMI from the old one to the new one. It seems to be XOR encoded. When I copy with HxD, the laptop boots, but the BIOS shows "INVALID" in the serial number, etc. How do I edit it correctly? Is there more than just behind LENV blocks? I'd like to be able to do it.
                          • peste
                            • Dec 2016
                            • 12887
                            • ROMANIA
                            #34
                            post S/N, full name and model, motherboard model,TYPE,etc.
                            post the original contents of the bios chip..
                            • Terz05
                              • Aug 2025
                              • 3
                              Its Lenovo V15-IGL
                              I managed it. After trying it manually many times, I found the Lenovo DMI Decryptor. It finally worked. Now I'm happy😅. Thanks to everyone. A really great community.​
                              • lucaszmn
                                by lucaszmn
                                Problem:
                                Initial Findings:
                                • I concluded that the
                                08-12-2025, 03:01 PM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
                              • grimacelord
                                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                by grimacelord
                                Hello there.
                                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                History:
                                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                I searched for this error online and discovered...
                                03-15-2023, 03:29 PM
                              • jendkkd jeje
                                Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                by jendkkd jeje
                                So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                10-11-2024, 03:12 PM
                              • 1g0r
                                Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                by 1g0r
                                First, the data in brief:
                                Manufacturer: Lenovo
                                Model: ThinkPad L15 G3 21C3-0016GE
                                motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                IC Bios 1: MX77L25650F
                                IC Bios 2​: MX25L25673G
                                EC Chip: NPCX997KAABX
                                So far I've been a silent reader, but now I need your help
                                I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                01-18-2025, 02:39 AM
