If I want I can do it but I have no problem reading and writing the chip I just need the right file.
Bios Lenovo V15-IGL
Here is your new file, it's a virgin BIOS from Lenovo with your DMI.
This file should works fine.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
34 and 28 is just the version so don't worry.
You have to use a 1.8v adapter if your chip needs 1.8v supply for sure. Also you have to choose verify after programming the chip to be sure that the written file is identical with your opened file.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I bought a 1.8V adapter, but when I try to do detect or write, it says:
Verify memory...
Verification error on address: 00000000
Execution time: 00:00:00.
I'm using the clip, and I don't think there are any connection issues. I'm using AsProgrammer, but I have problems even with other software, and the detect function doesn't work. However, I can read and verify, it lets me do that. Any suggestions?
​Comment
Could you help me with this bios please.​
Lenovo V15-IGL
Model : 82C3
S/N : PF39C5CJ
MTM : 82C3001WFRAttached Filesif you find these attachements useful please consider making a small donation to the site
V15-IGL Laptop (Lenovo) - Type 82C3
​Attached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
Hello
Thank you!
But it's not working.
I'm having a problem with this EEPROM
Winbond 25Q64JWSIQ
It's the third LENOVO laptop with this chip that I've tried to write and it fails.
There are some hexadecimal blocks that are different after erasing/writing/checking.
I use a EZP2023+ programmer
He recognizes the chip and reads it.
I've tried different write speeds, it's always the same blocks in error.
I don't have this problem with other laptop models
Do you have any idea where the problem may come from?​Comment
The bios chip must be unsoldered from the board before writing or reading..Hello
Thank you!
Winbond 25Q64JWSIQ
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
​Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I have a Lenovo V15-IGL laptop that originally had a BIOS password. I wasn’t able to reset it, so I flashed the BIOS using this file:
👉 https://www.badcaps.net/filedata/fetch?id=2082788
After flashing, the BIOS password issue is gone, but now:- The serial number and other system info appear incorrect or missing.
- It's asking for an HDD password, and I can’t access the drive.
Laptop Details:- Model: Lenovo V15-IGL
- Model Name: 82C3
- Serial Number: PF386JZ
- Motherboard: REV: 1.0 NM-D201 GV452/GV552 (2019-12-27)
HDD Details:- Brand: Seagate
- Model: ST1000LM035 (1TB)
- Serial Number: WKPT1BC6
I’ve uploaded the backup file — could the password or system info be inside it?
Any help or advice would be greatly appreciated.
Thanks in advance!Attached Filesif you find these attachements useful please consider making a small donation to the site
try.....
for hdd password...change hddAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I have the old bin file with the correct DMI data and a second DMI that corresponds to the most recent one on the manufacturer's website. However, I can't copy the DMI from the old one to the new one. It seems to be XOR encoded. When I copy with HxD, the laptop boots, but the BIOS shows "INVALID" in the serial number, etc. How do I edit it correctly? Is there more than just behind LENV blocks? I'd like to be able to do it.Comment
post S/N, full name and model, motherboard model,TYPE,etc.Hello, I have the old bin file with the correct DMI data and a second DMI that corresponds to the most recent one on the manufacturer's website. However, I can't copy the DMI from the old one to the new one. It seems to be XOR encoded. When I copy with HxD, the laptop boots, but the BIOS shows "INVALID" in the serial number, etc. How do I edit it correctly? Is there more than just behind LENV blocks? I'd like to be able to do it.
post the original contents of the bios chip..
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
