x513ea r5.3
    • 21433
    Originally posted by xplodpg
    Hi. I need bios for x513ea r5.3
    Post (TYPE) the laptop serial number and your backup..
    • xplodpg
      • Oct 2016
      • 30
      • Polska
      #102
      ok
      S/N: MCN0CV116178503
      MX25L12805D old k513e.zip
      • Kuhanzzi
        • Dec 2019
        • 20
        • Suomi
        #103
        Bios corrupt, cannot update with usb drive. Tested and got into bios with virgin bios. K513EA
        MB QR code decode: MA41NBCV00FH9SMB,MA41NBCV00FH9SMB,X513EAN,60NB0SG0-MB3021,532
        SN: MAN0CV20T100438
        • hoaca388
          Badcaps
          • Jan 2022
          • 12085
          #104
          ok
          X513EAN
            • 21433
            ok
            SN: MAN0CV20T100438
            Both of you want the X513EAN bios. Use the Asus F1 service bios from post 20, X513EANF1302.zip .Copy your DMI (serial number, windows key) from your backup to the new bios using the attached macro script, instructions are in the README text file.
            If you can use a hex editor these are the offsets: 660000 - 66FFFF .If you want to update from version 302 get the bios update from Asus support - https://www.asus.com/us/supportonly/...helpdesk_bios/
            • hoaca388
              Badcaps
              • Jan 2022
              • 12085
              #106
              SN: MAN0CV20T100438
              X513EAN
              • rajeshks
                • May 2009
                • 34
                #107
                Please clear my bios file. Booting time error message is coming. And i do it like showing. But still solve issue.
                I attached below error message. Serial No, mb part no and backup file.
                • shiyab
                  • Sep 2023
                  • 1539
                  • india
                  #108
                  hi try
                  • ehraneng
                    • Apr 2024
                    • it
                    #109
                    Please need bios .Thanks
                      • 21433
                      Type the laptop serial number, full name and model, motherboard model, etc.
                      post the contents of the bios chip even if it is corrupted..
                      read the forum rules..https://www.badcaps.net/forum/troubl...ore-posting​
                      If you have a good bios backup you can fix it yourself https://www.badcaps.net/forum/troubl...75#post3632375
                      • btomce
                        • Nov 2020
                        • 70
                        • lt
                        #111
                        Please disable onboard RAM from my bios/ x513ean
                        MC49NBCV00CBM
                        MMB,MC49NBCV00
                        C8MMMB,X513EAN
                        60NB0SG0-MB3120,535
                        Thanks A LOT
                          • 21433
                          MC49NBCV00CBM
                          MMB,MC49NBCV00
                          C8MMMB,X513EAN
                          60NB0SG0-MB3120,535
                          Thanks A LOT
                          Try the ram patcher script - https://www.badcaps.net/forum/troubl...20#post3232220
                          • mikeybass
                            by mikeybass
                            04-23-2025, 04:30 PM
                          • akwky
                            by akwky
                            Hi!
                            04-14-2025, 01:56 PM
                          • al3m0di
                            Update bios EFCN58WW to EFCN59WW
                            by al3m0di
                            Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                            I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                            The BIOS version is EFCN58WW.
                            When I turn on the device, it displays the message:
                            "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                            The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                            I've tried
                            07-29-2024, 10:32 AM
                          • 0xx
                            2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                            by 0xx
                            Hi folks,
                            My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                            What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                            I assumed that Windows Update was interrupted due to closing...
                            09-14-2025, 03:46 PM
                          • trix11
                            Dell Precision T1650 MT Workstation bricked after BIOS update
                            by trix11
                            I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                            - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                            - Dell Precision T1650 mid tower Workstation
                            - Xeon E3-1225 V2
                            - 32Gb PC3-12800E RAM
                            - 4Tb SATA HDD
                            - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                            I see now that others have experienced like issues e.g.:
                            - https://www.dell.com/community/Prec...
                            10-24-2022, 10:35 PM
