Hp 14-dq****** 14s-dq****** DA0PAMB46A0 DA0PAMB46A1
  • dedy mardinata
    • Jul 2023
    • indonesia
    need bios hp 14s-dq0508tu
    sn : 5cd14851h0
    kode board : da0pamb46a0 rev:a
    original file :
    • peste
      • 13176
      • ROMANIA
      sn : 5cd14851h0
      original file :
      try post #9...0864D
      DMI 747000 - 7480FF
      KEY WIN 76D000 - 76D03F
      • dedy mardinata
        • Jul 2023
        • indonesia
        Originally posted by peste
        try post #9...0864D
        DMI 747000 - 7480FF
        not working sir
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          not working sir
          maybe you have other issue
          • than_22
            • Sep 2017
            • 53
            • philippines
            Please help me repair my bios,,
            laptop no display after updating windows with 5 long and 3 short blink in capslock
            Board ID is DA0PAMB46A1 REV:A
            SN : 5CD2O6OSFP​
              SMDFlea commented
              Editing a comment
              Post moved to 14s-dq thread
          • hoaca388
            Badcaps
            • Jan 2022
            • 12085
            #26
            SN : 5CD2O6OSFP
            HP Laptop 14s-dq0509TU (58Y79PA)
              SMDFlea commented
              Editing a comment
              Wrong BID , should be BID0864D
            • 21439
            SN : 5CD2O6OSFP
            Use the Guides to find and extract a virgin bios
            [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
            [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
            Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
            Offsets:
            747000 - 7480FF
            76D000 - 76D03F​
            HxD Hex editor https://mh-nexus.de/en/hxd/
            • Tekryan0721
              • Oct 2020
              • 12
              • Philippines
              #28
              good day everyone, i need help with my file, charging light only wont turn on,
              tried other bin files, with power light no display, processor no heat.
              my original file is only 4MB, other files are 8mb, No luck on NsydeFlash too. Thank you
              14S-0509tu
              SN: 5CD203C35Y
              ProdID: 58Y79PA#UUF
              DA0PAMB46A1 REV A
              orig nios BID 0864D F.30
              • hoaca388
                Badcaps
                • Jan 2022
                • 12085
                #29
                14S-0509tu
                SN: 5CD203C35Y
                ProdID: 58Y79PA#UUF
                DA0PAMB46A1 REV A
                You need a programmer, for example​ : CH341A
                https://www.youtube.com/results?sear...mer+how+to+use
                • kuraimangetsu
                  • Nov 2022
                  • 77
                  • iraq
                  #30
                  HP 14S-dq0034na
                  sn:5CD443C93G
                  TPN-Q22T
                  BOARD: HP DA0PAMB46A1 REV A
                  ORIGINAL BIOS ATTACHED
                  need bios plz
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12085
                    #31
                    Originally posted by kuraimangetsu
                    HP 14S-dq0034na
                    sn:5CD443C93G
                    TPN-Q22T
                    need bios plz
                    HP Laptop 14s-dq0034na (893D3EA)
                    BID : 0864D
                    • kuraimangetsu
                      • Nov 2022
                      • 77
                      • iraq
                      #32
                      BID : 0864D
                      thanks. but still same problem
                      black screen with 5 long + 3 short led blinks on the caps lock
                      checked multiple ram modules as well
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12085
                        #33
                        You don't have any problem with bios, focus on hardware failure.
                        • one99
                          • Oct 2024
                          • GUERRERO
                          #34
                          BUSCO BIOS HP
                          da0pamb46a1 rev a
                          model: 0pab
                          agrego mi archivo original
                          sin imagen y la tecla de mayusculas parpadea
                          • danito
                            • Jun 2016
                            • 1040
                            #35
                            Originally posted by one99
                            BUSCO BIOS HP
                            da0pamb46a1 rev a
                            model: 0pab
                            try post #22 or #27
                            • Chibest
                              • Aug 2022
                              • 7
                              • Nigeria
                              #36
                              DA0PAMB46A1 REV A
                              CLEAN ME PLEASE
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12085
                                #37
                                Originally posted by Chibest
                                DA0PAMB46A1 REV A
                                CLEAN ME PLEASE
                                Serial number ?
                                • Chibest
                                  • Aug 2022
                                  • 7
                                  • Nigeria
                                  #38
                                  SN 5CD44342CV
                                  Please help a brother
                                  caps lock blinks 5 times and 3 times
                                  • Chibest
                                    • Aug 2022
                                    • 7
                                    • Nigeria
                                    #39
                                    DA0PAMB46A1 REV A
                                    HP14 DQ0052DX
                                    SN: 5CD44342CV
                                    caps blinks 5times and 3times
                                    please help me cus its urgent
                                    • Chibest
                                      • Aug 2022
                                      • 7
                                      • Nigeria
                                      #40
                                      someone should please help a friend
                                      • epoy
                                        NEED SCHEMATIC FOR HP 14S-DQ0509TU DA0PAMB46A1
                                        by epoy
                                        Good day Masters
                                        NEED SCHEMATIC/BOARDVIEW FOR HP 14S-DQ0509TU
                                        BOARD code - DA0PAMB46A1 REV:A...
                                        07-05-2024, 09:45 PM
                                      • nelsaiah21
                                        bios needed for Hp 14-dq0001dx (DA0PAMB46A0)
                                        by nelsaiah21
                                        Good day sir! can i ask help for my Hp 14-dq0001dx (DA0PAMB46A0), i badly needed bios for this unit... thank you very much for help.. i include my bad bios here thanks....
                                        06-15-2022, 07:05 PM
                                      • grimacelord
                                        HP 14-dq0055dx - No Power After Shutdown - Must Reseat Internal Battery First, Then Powers On Normally.
                                        by grimacelord
                                        Hello again,
                                        I am once again working on this same laptop that I was working on in this thread. I was able to fix all of the problems that it had, but now it has one final problem. The computer will turn on and work completely fine until you shut it down. Once the computer has been shut down, it will not turn on again, nor will it show charging LED until the internal battery is disconnected and then reconnected. Once the battery has been disconnected and reconnected, the computer will then power on and charge normally and everything is fine again until the next shut down where you...
                                        05-22-2024, 02:32 PM
                                      • grimacelord
                                        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                        by grimacelord
                                        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                        Motherboard model number: DA0PAMB46A1 REV: A
                                        Secondary motherboard model number: 0PAB
                                        SKU: 685K4UA
                                        Serial number is: 5CD3223BJP
                                        Recently reflashed this laptop with latest BIOS and once...
                                        05-07-2024, 08:06 AM
                                      • grimacelord
                                        HP 14-dq0055dx - BIOS problem - "Pending Image Being Cleared" Loop
                                        by grimacelord
                                        I have an HP 14-dq0055dx laptop here that came in for boot looping. It was previously taken to another shop and they tried flashing a BIOS firmware to the chip, so I cannot take an original dump. For a second or two, a message will come up on the screen that says:
                                        This loop will go on for as long as you like. I let it run for about 12 hours and came in the following morning and it's still looping.
                                        SKU: 685K4UA
                                        Attached is the latest...
                                        04-30-2024, 09:11 AM
