Hp 14-dq****** 14s-dq****** DA0PAMB46A0 DA0PAMB46A1
  • hoaca388
    Badcaps
    • Jan 2022
    • 12085
    #41
    Originally posted by Chibest
    someone should please help a friend
    HP Laptop 14-dq0052dx (685K1UA)
    • epoy
      NEED SCHEMATIC FOR HP 14S-DQ0509TU DA0PAMB46A1
      by epoy
      Good day Masters
      NEED SCHEMATIC/BOARDVIEW FOR HP 14S-DQ0509TU
      BOARD code - DA0PAMB46A1 REV:A...
      07-05-2024, 09:45 PM
    • nelsaiah21
      bios needed for Hp 14-dq0001dx (DA0PAMB46A0)
      by nelsaiah21
      Good day sir! can i ask help for my Hp 14-dq0001dx (DA0PAMB46A0), i badly needed bios for this unit... thank you very much for help.. i include my bad bios here thanks....
      06-15-2022, 07:05 PM
    • grimacelord
      HP 14-dq0055dx - No Power After Shutdown - Must Reseat Internal Battery First, Then Powers On Normally.
      by grimacelord
      Hello again,
      I am once again working on this same laptop that I was working on in this thread. I was able to fix all of the problems that it had, but now it has one final problem. The computer will turn on and work completely fine until you shut it down. Once the computer has been shut down, it will not turn on again, nor will it show charging LED until the internal battery is disconnected and then reconnected. Once the battery has been disconnected and reconnected, the computer will then power on and charge normally and everything is fine again until the next shut down where you...
      05-22-2024, 02:32 PM
    • grimacelord
      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
      by grimacelord
      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
      Motherboard model number: DA0PAMB46A1 REV: A
      Secondary motherboard model number: 0PAB
      SKU: 685K4UA
      Serial number is: 5CD3223BJP
      Recently reflashed this laptop with latest BIOS and once...
      05-07-2024, 08:06 AM
    • grimacelord
      HP 14-dq0055dx - BIOS problem - "Pending Image Being Cleared" Loop
      by grimacelord
      I have an HP 14-dq0055dx laptop here that came in for boot looping. It was previously taken to another shop and they tried flashing a BIOS firmware to the chip, so I cannot take an original dump. For a second or two, a message will come up on the screen that says:
      This loop will go on for as long as you like. I let it run for about 12 hours and came in the following morning and it's still looping.
      SKU: 685K4UA
      Attached is the latest...
      04-30-2024, 09:11 AM
