Hp 14-dq****** 14s-dq****** DA0PAMB46A0 DA0PAMB46A1
  • dedy mardinata
    • Jul 2023
    • indonesia
    need bios hp 14s-dq0508tu
    sn : 5cd14851h0
    kode board : da0pamb46a0 rev:a
    original file :
    • peste
      • Dec 2016
      • 12666
      • ROMANIA
      sn : 5cd14851h0
      original file :
      try post #9...0864D
      DMI 747000 - 7480FF
      KEY WIN 76D000 - 76D03F
      • dedy mardinata
        • Jul 2023
        • indonesia
        Originally posted by peste
        try post #9...0864D
        DMI 747000 - 7480FF
        not working sir
        • kalilinux25
          • Mar 2018
          • 2084
          • ZAMBOANGA SIBUGAY
          not working sir
          maybe you have other issue
          • than_22
            • Sep 2017
            • 53
            • philippines
            Please help me repair my bios,,
            laptop no display after updating windows with 5 long and 3 short blink in capslock
            Board ID is DA0PAMB46A1 REV:A
            SN : 5CD2O6OSFP​
              SMDFlea commented
              Editing a comment
              Post moved to 14s-dq thread
          • hoaca388
            Badcaps
            • Jan 2022
            • 11656
            #26
            SN : 5CD2O6OSFP
            HP Laptop 14s-dq0509TU (58Y79PA)
              SMDFlea commented
              Editing a comment
              Wrong BID , should be BID0864D
            • 20720
            SN : 5CD2O6OSFP
            Use the Guides to find and extract a virgin bios
            [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
            [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
            Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
            Offsets:
            747000 - 7480FF
            76D000 - 76D03F​
            HxD Hex editor https://mh-nexus.de/en/hxd/
            • Tekryan0721
              • Oct 2020
              • 12
              • Philippines
              #28
              good day everyone, i need help with my file, charging light only wont turn on,
              tried other bin files, with power light no display, processor no heat.
              my original file is only 4MB, other files are 8mb, No luck on NsydeFlash too. Thank you
              14S-0509tu
              SN: 5CD203C35Y
              ProdID: 58Y79PA#UUF
              DA0PAMB46A1 REV A
              orig nios BID 0864D F.30
              • hoaca388
                Badcaps
                • Jan 2022
                • 11656
                #29
                14S-0509tu
                SN: 5CD203C35Y
                ProdID: 58Y79PA#UUF
                DA0PAMB46A1 REV A
                You need a programmer, for example​ : CH341A
                https://www.youtube.com/results?sear...mer+how+to+use
                • kuraimangetsu
                  • Nov 2022
                  • 76
                  • iraq
                  #30
                  HP 14S-dq0034na
                  sn:5CD443C93G
                  TPN-Q22T
                  BOARD: HP DA0PAMB46A1 REV A
                  ORIGINAL BIOS ATTACHED
                  need bios plz
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11656
                    #31
                    Originally posted by kuraimangetsu
                    HP 14S-dq0034na
                    sn:5CD443C93G
                    TPN-Q22T
                    need bios plz
                    HP Laptop 14s-dq0034na (893D3EA)
                    BID : 0864D
                    • kuraimangetsu
                      • Nov 2022
                      • 76
                      • iraq
                      #32
                      BID : 0864D
                      thanks. but still same problem
                      black screen with 5 long + 3 short led blinks on the caps lock
                      checked multiple ram modules as well
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11656
                        #33
                        You don't have any problem with bios, focus on hardware failure.
                        • one99
                          • Oct 2024
                          • 3
                          • GUERRERO
                          #34
                          BUSCO BIOS HP
                          da0pamb46a1 rev a
                          model: 0pab
                          agrego mi archivo original
                          sin imagen y la tecla de mayusculas parpadea
                          • danito
                            • Jun 2016
                            • 898
                            • Romania
                            #35
                            Originally posted by one99
                            BUSCO BIOS HP
                            da0pamb46a1 rev a
                            model: 0pab
                            try post #22 or #27
                            • Chibest
                              • Aug 2022
                              • 7
                              • Nigeria
                              #36
                              DA0PAMB46A1 REV A
                              CLEAN ME PLEASE
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11656
                                #37
                                Originally posted by Chibest
                                DA0PAMB46A1 REV A
                                CLEAN ME PLEASE
                                Serial number ?
                                • Chibest
                                  • Aug 2022
                                  • 7
                                  • Nigeria
                                  #38
                                  SN 5CD44342CV
                                  Please help a brother
                                  caps lock blinks 5 times and 3 times
                                  • Chibest
                                    • Aug 2022
                                    • 7
                                    • Nigeria
                                    #39
                                    DA0PAMB46A1 REV A
                                    HP14 DQ0052DX
                                    SN: 5CD44342CV
                                    caps blinks 5times and 3times
                                    please help me cus its urgent
                                    • Chibest
                                      • Aug 2022
                                      • 7
                                      • Nigeria
                                      #40
                                      someone should please help a friend
