Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • Septian
    • Jan 2024
    • 19
    • Indonesia
    #101
    Hello bro, I need help
    Lenovo laptop with board code like the picture I uploaded, but I can't give you the complete type of laptop because the sticker on the laptop has come off.
    I had a laptop no display problem after updating Windows, then I flashed the bios IC with the file here, the laptop indicator flashed, please repair my old bios file bro, thx
    • Alexander Inciong
      • Philippines
      #102
      Hello everyone just new here on badcaps and find this same issue with you. Blackscreen stable power led
      BOARD NUMBER : HS461&HS561&HS761 NM-D521 Rev 2.0
      MO: L39411616081
      MTM: 82KT002LPH
      S/N: PC20KHXC
      Here is my Backup OLD BIOS. Tried copying the DMI : 1000h --> 2FFF But those are valued from 1000 FF only I assume this is corrupted also
      Can you please help me add my S/N to the bin on virgin # 56 post
      • peste
        • 13721
        • ROMANIA
        #103
        MO: L39411616081
        MTM: 82KT002LPH
        S/N: PC20KHXC
        use the HxD program (you can find it for free)..include both bios in it and copy that interval where the DMI information from the original bios is found in the bios from post#56...(copy-paste)...
          • 22085
          MO: L39411616081
          MTM: 82KT002LPH
          S/N: PC20KHXC
          If you can`t use a hex editor use the script in this post to add it https://www.badcaps.net/forum/troubl...08#post1605508
          • Alexander Inciong
            • Philippines
            #105
ID:	3304997​​​​​update everyone. This unit came from other computershop and the BIOS it came is Winbond but the voltage is 3.3v i assume this was replaced. will it work if the Bios chip is 3.3v instead of winbond that have 1.8v or do I buy that 1.8v bioschip
            • gxtsss
              • Oct 2018
              • lithuania
              #106
              Hello maybe any can repair my bios?
              Model: V15 G2-ALC Laptop (Lenovo) - Type 82KD
              S/n:PF42AZVT
              BOARD: HV461&HV561 NM-D522 REV: 2.0
              • volinakis
                • Jan 2021
                • 2875
                • N/A
                #107
                S/n:PF42AZVT
                try
                • gxtsss
                  • Oct 2018
                  • lithuania
                  #108
                  Originally posted by volinakis
                  try
                  Its working but no s/n nothing and no os license key
                  • volinakis
                    • Jan 2021
                    • 2875
                    • N/A
                    #109
                    I made the transfer of DMI to new bios. DMI is encrypted as you see in picture. try this one:
                    • gxtsss
                      • Oct 2018
                      • lithuania
                      #110
                      Thanks!!
                      • Alexander Inciong
                        • Philippines
                        #111
                        Originally posted by martindlm
                        Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
                        Hello, I share a dump extracted from a working nm-d521 board.
                        Hello Martindlm thanks for the dump my laptop is working now
                        • Alexander Inciong
                          • Philippines
                          #112
                          I successfully replace my S/N ,MO and MTM via tool called Lenovo GoldenKey U1 Tool. Thank you again everyone the laptop works great now
                          • Victor morales delgado
                            • Jan 2024
                            • chile
                            #113
                            anyone can helpme? SN PF35CEYE
                            oldbios as the backup.
                            model: ideapad 3 14LC6
                            issue: error 0x0000185
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12403
                              #114
                              IdeaPad 3-14ALC6 Laptop - Type 82KT
                              • braiam2022
                                • Aug 2024
                                • Brasil
                                #115
                                please bios my laptop lenovo ideapad 3 15ALC6
                                S/N : PE08RDEC
                                MO : PE9012311000
                                MTM : 82MF0004BR
                                Board: HS461$HS561$HS761 NM-D521
                                2020 - 12 - 11 REV 2.0
                                I don't have an old bios
                                Ryzen 7-5700U
                                • kalilinux25
                                  • Mar 2018
                                  • 2093
                                  • ZAMBOANGA SIBUGAY
                                  #116
                                  S/N : PE08RDEC
                                  MO : PE9012311000
                                  MTM : 82MF0004BR
                                  Ryzen 7-5700U
                                  try this one from a working board change the seral number using U1 TOOL https://www.badcaps.net/forum/troubl...r-bootable-usb
                                  • braiam2022
                                    • Aug 2024
                                    • Brasil
                                    #117
                                    Could someone do this procedure for me? I'm Brazilian and I don't know how to use this app mentioned
                                    • kalilinux25
                                      • Mar 2018
                                      • 2093
                                      • ZAMBOANGA SIBUGAY
                                      #118
                                      did you already flash the bin file? did the laptop power on and display?
                                      • braiam2022
                                        • Aug 2024
                                        • Brasil
                                        #119
                                        I'm not able to or know how to use the program to update the bin file, could you update it for me?​
                                        • kalilinux25
                                          • Mar 2018
                                          • 2093
                                          • ZAMBOANGA SIBUGAY
                                          #120
                                          do you have a SPI programmer?
                                          • Marc97
                                            lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
                                            by Marc97
                                            hello there,, anyone who can help us to have bios for LENOVO
                                            HS461 HS561 HS761 NM-D251 REV 2.0
                                            I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
                                            i attached the .CAP may you can help us also to trim it.....
                                            12-03-2022, 05:51 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
