Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • m1ch43lzm
    • Mar 2019
    • 1008
    • Peru
    #181
    Originally posted by norobert
    Bios please.
    I have a question. What do I need to modify or repair to make the corrupted file work?
    ideapad3 14 alc6
    sn PF3DX8CK
    Thanks!!!!
    See the answer above your post, anyway here it is
    BIOS from post 52 with your DMI added
    • norobert
      • May 2020
      • 10
      • argentina
      #182
      Thanks soo much!!!
      • delija89
        • Jan 2024
        • Serbia
        #183
        Hello all again,
        I have a problem I think with bios. When enter bios i have MTM and Lenovo SN = INVALID and after few seconds then turn off.
        IdeaPad 3-15ALC6 Laptop - Type 82KU
        AMD Ryzen™ 5 5500U Processor
        Serial Number: PF3HNABF
        MTN: 82KU006LYA
        Motherboard: hs461&hs561&hs761 nm-d521 rev 3.0
        In attachment is BIOS.
        Best regards,
        Delija
        • peste
          • 13718
          • ROMANIA
          #184
          Originally posted by delija89
          Hello all again,
          MTN: 82KU006LYA
          Best regards,
          Delija
          you have everything you need at post #52...
          https://www.badcaps.net/forum/troubl...bios-plz/page3
          • Guaculo
            • Jul 2020
            • 7
            • US
            #185
            Hi, hope you are doing great.
            I need to flash BIOS on a Lenovo IdeaPad 3 (Takes power, keyboard backlight lights on for a second, power button blinks all time, rest of the keyboard keys stay put, CPU gets warm)
            15ALC6
            S/N: PC295HXH
            MTM: 82KU00YWUS
            Mfg Date: 2021/12/18
            Board: HS461&HS561&HS761 NM-D521 Rev: 3.0 2021-05-08
            Thank you very much.
            • Guaculo
              • Jul 2020
              • 7
              • US
              #186
              15ALC6
              S/N: PC295HXH
              MTM: 82KU00YWUS
              I followed the instructions on post 52 Pasted the block from 1000 to 2fff from old bios to new bios, but didn't work, laptop behaves the same. Attached is the file i flashed.
              • peste
                • 13718
                • ROMANIA
                #187
                The bios you posted is empty and only has 4Mb...it should have 16 MB...make a new copy and post again..
                • Guaculo
                  • Jul 2020
                  • 7
                  • US
                  #188
                  Thats what came out from the programmer from the original BIOS, maybe thats why it was bad? I flashed it with the new BIOS anyways so it is lost. Is there a way i can configure a new BIOS from the start?
                  • m1ch43lzm
                    • Mar 2019
                    • 1008
                    • Peru
                    #189
                    You selected wrong chip model MX25U3235F (that's what the file name says), the BIOS chip should have 25*128 on its name (16 MB)
                    Your first backup is full of FF FF FF .... the chip was not read properly or erased before
                    Try again, select the correct chip model, if you have a 74M12JW select W25Q128JW on your programmer software
                    Flash post 52 as is (select the correct BIOS chip model first), you don't have a good original backup to transfer the DMI from, Laptop should boot and display INVALID serial/MTM/model name so you have to use Golden Key to enter model/serial/MTM after laptop boots
                    https://www.badcaps.net/forum/troubl...r-bootable-usb
                    • Guaculo
                      • Jul 2020
                      • 7
                      • US
                      #190
                      I flashed BIOS from post 52 with W25Q128JW selected, but still same behavior from the laptop. I notice the power button starts flashing as soon as i press it, possible bad CPU?
                      • Marc97
                        lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
                        by Marc97
                        hello there,, anyone who can help us to have bios for LENOVO
                        HS461 HS561 HS761 NM-D251 REV 2.0
                        I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
                        i attached the .CAP may you can help us also to trim it.....
                        12-03-2022, 05:51 PM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
