Bricked Asus GL502VMZ bios need help using CH341A
  • abdomsr
    • Dec 2021
    • Morocco
    need help please bios was bricked by windows update "Asus GL502VMZ"
    bios chip 'W25Q64FV' i'm trying CH341A and asprogrammed 1.41 and i get this message
    "Current programmer: CH341
    Old SREG: 11111111(0xFF), 11111111(0xFF)"
    need some help modding the new bios i think it will fix the error 'as mentioned on another thread'
    • 22279
    Re: Bricked Asus GL502VMZ bios need help using CH341A
    Your backup isn`t good.Try NeoProgrammer software instead -
    https://www.badcaps.net/forum/showpo...50&postcount=5
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • studdy05
      Bricked HP Probook 450 G7 Bios questions
      by studdy05
      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
      Ive got...
      07-08-2025, 09:24 PM
