Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • marc_ytos
    • Apr 2020
    • 154
    • cdmx
    #501
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Greetings, please can someone help me remove the bios password and I tried to modify it with exadecimal and I was not successful. My computer model is elitebook 840 g8, serial number 5CG1314HSN, motherboard model 6050a3217501-mb-a01, thank you very much in advance.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12249
      #502
      Elitebook 840 g8
      • marc_ytos
        • Apr 2020
        • 154
        • cdmx
        #503
        Originally posted by hoaca388
        Elitebook 840 g8
        Thank you very much, it was corrected with the file you sent me by copying my region. I really appreciate your support, without you I would not have been able to solve this
        • adilattack
          • Sep 2018
          • 36
          • Network
          #504
          hp elitebook 850 g8 sn 5CG2321HJM, thank you very much in advance
          • hoaca388
            Badcaps
            • Jan 2022
            • 12249
            #505
            • adilattack
              • Sep 2018
              • 36
              • Network
              #506
              thanks for help
              • hyditech
                • Jun 2012
                • 272
                • nigeria
                #507
                Hi everyone good evening, please i have 840 g8 with bios password... 11th gen.
                S\N 5CG2157WVT
                please help me unlock.. thank you
                • haiermobile
                  • Sep 2017
                  • 8
                  • pakistan
                  #508
                  hp 840 g8 bios help dead no switching from power button
                  charging light shows only
                  i tried above bios in this forum 2 bios give display but didnt boot os
                    • 21634
                      • 21634
                      S\N 5CG2157WVT
                      try this https://www.badcaps.net/forum/showpo...5&postcount=68
                      • hyditech
                        • Jun 2012
                        • 272
                        • nigeria
                        #511
                        i should use the file direct?
                        my is 840 g8 and the file i see is 440 g8
                          • 21634
                          It will remove the password,the model number doesn`t matter,it should work for all the HP 32MB EC bios.Read the README file
                          • hyditech
                            • Jun 2012
                            • 272
                            • nigeria
                            #513
                            Originally posted by SMDFlea
                            It didnt work sir...can you help me with my bin
                              • 21634
                              Well,if you really did use the script and Tiny Hexer properly and flashed the bios back again,you must have another password in the main bios.
                              • hyditech
                                • Jun 2012
                                • 272
                                • nigeria
                                #515
                                I was able to install it and it work ok. but bios password is still there...
                                should i also flash the main bios?
                                because the passoword didnt remove
                                • hyditech
                                  • Jun 2012
                                  • 272
                                  • nigeria
                                  #516
                                  i am sorry,but i still want to get it right... i just flash the the main bios now and pass word is still there...
                                  wen i run 440 g8 unlock,it will run well and it will bring back another 32mb.bin.bak...
                                  i dont know if it should write unlock before i know it has work well... because it doesnt write that..
                                    • 21634
                                    You should not run the script on the main bios,did you read the warning
                                    This must ONLY be used with the 32MB EC NOT the main bios !!!!
                                    Post your main 32MB bios and someone will help.
                                    • hyditech
                                      • Jun 2012
                                      • 272
                                      • nigeria
                                      #518
                                      here are the two bios Main and EC
                                      Thank you..
                                      • rex98
                                        • Feb 2023
                                        • 1289
                                        • Mandaue CEBU, Philippines
                                        #519
                                        Thank you..
                                        S\N 5CG2157WVT
                                        flash only this EC 2nd chip. it will promt endpoint security controller just ignore it enter. it will disappear in next boot.
                                        next time use any hex editor fill with ff in this offset 00037000 to 000379df
                                        • hyditech
                                          • Jun 2012
                                          • 272
                                          • nigeria
                                          #520
                                          Originally posted by rex98
                                          S\N 5CG2157WVT
                                          thank you so so much... Password cleared.....Please can you guide me on how you did it...i will want to do it myself...Because i still have 3 more that i need to do and i dont want be asking much...
                                          but thank you i really appreciate...
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
