GP152 LA-J951P Rev: 1.0 bios request
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    #41
    Originally posted by Yacine007
    XMC
    QH128AHIG
    PP990200 40
    2008C
    yep, your backup is wrong, should have 16.777.216 bytes. Use SMDFlea's file from post #29 and select right chipset in your software programmer. If you have CH341A use AsProgrammer.
    • Yacine007
      • May 2024
      • 92
      • Maroc
      #42
      Originally posted by SMDFlea
      Try this one. Its a 16MB virgin bios with your DMI. Can you confirm the bios chip is 16MB or 8MB.If its 8MB its the wrong one.If its 16MB i can only guess that your programmer has detected the chip as only 8MB, or you chose the wrong one
      hi my knowledge is so basic so I used a software version that does not support my bios chip xmc 16mb then the backup is wrong, im sorry for that !
      i will try your bin and let you know the result.
      thank you very much
      • Yacine007
        • May 2024
        • 92
        • Maroc
        #43
        thank you my friend for attention 🙏 i will try and give you the result
        • vatecnica
          • May 2021
          • 45
          • Argentina
          #44
          Hello fiends! still dont know how to build a bios with no image! y have an 250 g7 with no video,,fan spin for a sec then power off, then again power on, all rails al ok y have all the voltages!
          prod id:153BLT#AC8
          SN: CND0295RM2
          hope you can help me!
          guess i need to lern how to build a bios! thanks a lot!​
          • shiyab
            • Sep 2023
            • 1680
            • india
            #45
            prod id:153BLT#AC8
            SN: CND0295RM2
            hi try
            • vatecnica
              • May 2021
              • 45
              • Argentina
              #46
              Originally posted by shiyab
              hi try
              hello friend, the pc now wont power off but i have no image on display! thats good now!
              • shiyab
                • Sep 2023
                • 1680
                • india
                #47
                hi try
                • vatecnica
                  • May 2021
                  • 45
                  • Argentina
                  #48
                  hi,,no image via hdmi or display in the computer!
                  could be the me region?
                  it has an i3 this machine!
                  • shiyab
                    • Sep 2023
                    • 1680
                    • india
                    #49
                    check hardware
                    • vatecnica
                      • May 2021
                      • 45
                      • Argentina
                      #50
                      check hardware
                      all power rails are ok,,, but display turn on in black,,, y saw that,, could be the wrong bios? in th support i download the bios and 3 of them are 16mb i will try all 3 and tell you! thanks a lot friend!
                      • dahnking
                        • Apr 2018
                        • 265
                        • kenya
                        #51
                        Originally posted by Atiq
                        Re: GP152 LA-J951P Rev: 1.0 bios request
                        I have a good working bios from a good working laptop. working 100%
                        Working tested
                        Thank you
                        • sirzat
                          • Jun 2015
                          • 30
                          • Tekirdag
                          #52
                          Hello, the original bios of the device keeps resetting. Is there a chance to fix the error?
                          Motherboard: GPI52 LA-J951P Rev 1.0
                          HP 250 G7 1F3M9EA
                          BID086C1
                          P. ID : 1F3M9EA#AB8
                          SN : CND1061FXV
                          Thank you in advance for your help.
                          • peste
                            • Dec 2016
                            • 13853
                            • ROMANIA
                            #53
                            HP 250 G7 1F3M9EA
                            BID086C1
                            P. ID : 1F3M9EA#AB8
                            SN : CND1061FXV
                            you have everything you need at post #14
                            https://www.badcaps.net/forum/troubl...-0#post3267525
                            • sirzat
                              • Jun 2015
                              • 30
                              • Tekirdag
                              #54
                              The file in the 15th message did the job for me.
                              The device is working fine now.
                              Thank you very much for your help.​
                              • kamkooltech
                                kamkooltech
                                • Jun 2019
                                • 132
                                • nigeria
                                #55
                                Its none of those. The 15S43ES has an Ice Lake CPU
                                084A6 SPT/KBP-LP ME 11 firmware
                                084A8 BSW/CHT TXE 2 firmware
                                084AA GLK (Gemini Lake) TXE 4 firmware
                                How did you got this informations????
                              • cr4zychriss
                                by cr4zychriss
                                • Rebrand: PC Specialist
                                11-14-2025, 04:04 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
                              • hotcrossedbuns999
                                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                by hotcrossedbuns999
                                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                3. I could only locate two chips that look like bios chips. Could someone verify this
                                01-03-2025, 12:32 PM
