HP 15-ba025nv, la-d711p rev 3.0, FULL FAN NO IMAGE, FIX BIOS
  • mantza
    • Sep 2020
    • 36
    • GREECE
    Hello, can someone fix this bios
    with the other one i extracted from the hp website it works but no info
    • 22293
    Re: HP 15-ba025nv, la-d711p rev 3.0, FULL FAN NO IMAGE, FIX BIOS
    Copy the DMI from the offsets provided in the picture.Copy from the old and paste-inset into the new bios using the same offsets.
    HxD hex editor https://mh-nexus.de/en/hxd/
    • mantza
      • Sep 2020
      • 36
      • GREECE
      Thank you i will try and post results
      do you know if there is a way to fix
      manufacture programming mode is in unlock mode
      from editing the bios file?
      so i don't have to run the hp program afterwards
        • 22293
        Yes just leave it,it will lock itself after 30 or so reboots.
        • mantza
          • Sep 2020
          • 36
          • GREECE
          it worked for the info, but the 30 reboots did not work, i will do it with the hp program
          thanks
          • Leonardoa26
            • May 2022
            • 3
            • Venezuela
            hello friends, I hope you can help me, I have a good HP 15 ba021ca BDL51 LA-D711P R 3.0, it only turns on the charging led and when I turn it on, it turns on the power led for a few seconds, I already programmed the bios, maybe it is the EC chip, someone will have the files to program this chip?
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              post the original laptop bios here.
              • by_mex
                • Feb 2014
                • 57
                • turkey
                The attached bios works fine, I tested it.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  This file already contains a filled DMI block (i.e. is copied from a working machine), the file in post #1 (working no info 082F6.rar) is virgin dump from HP, the DMI information should be copied from the old dump to the one at the first post.
                  I don't see any point in using any other file other than a virgin one from the manufacturer's site.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • kamkooltech
                    kamkooltech
                    • Jun 2019
                    • 132
                    • nigeria
                    1000000000000000000000000% working
                    • beal
                      • Jul 2017
                      • 125
                      • IR
                      100% working
                      very thanks
                      • Sudeera Chanaka
                        • Apr 2023
                        • 3
                        • Sri lanka
                        THANK YOU BRO
                        • Focus2005
                          HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                          by Focus2005
                          Hello everyone.
                          I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                          05-01-2025, 05:41 AM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
                        • grimacelord
                          Latitude E6530 - Trouble Extracting BIOS Image From EXE
                          by grimacelord
                          Hi folks,
                          I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                          Service tag number for this model is: "JYDWYW1".
                          Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                          I have tried:
                          • Simply extracting with 7zip
                          • PFSExtractor
                          • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                          • Check Temp folder
                          10-26-2023, 08:15 AM
                        • istvanszasz99
                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                          by istvanszasz99
                          Product Name: Razer Blade 15 (2022)
                          Product ID: RZ09-0421
                          Motherboard: CH580
                          BIOS Versions I work with: 2.02 & 2.06
                          Bios File Size: 32,768 KB
                          Dear Forum Readers!
                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                          !!! MY RAZER BLADE...
                          11-24-2025, 05:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
