need bios dump dell latitude 5420 (cpu 11th)
    • 22176
    Originally posted by mdrirfan@gmail.com
    I can see the screen on the laptop but backlight is not turning on. I see a dim screen on laptop and when i presss any key on th ekeyboard it maskes noise.
    It`s not a bios problem, it`s hardware.
    • nafienew
      • Aug 2014
      • 116
      • up
      #862
      Dell Latitude 5420 Main GDF40 LA-K491P rev 2.0
      model P137G
      ST C4C44F3
      need disable absolute
      • LBTT1121
        • Nov 2024
        • 1216
        • Việt Nam
        #863
        model P137G
        ST C4C44F3
        try and feedback
        • nafienew
          • Aug 2014
          • 116
          • up
          #864
          Originally posted by LBTT1121
          try and feedback
          Thank you, the device is working but it keeps getting stuck on the Dell logo.?
          Dell Latitude 5420 Main GDF40 LA-K491P rev 2.0 (cpu 11th)
          model P137G
          ST C4C44F3
          • shiyab
            • Sep 2023
            • 1676
            • india
            #865
            model P137G
            ST C4C44F3
            hi try
            • nafienew
              • Aug 2014
              • 116
              • up
              #866
              Originally posted by shiyab
              hi try
              Thank you, the device is working, but the image does not appear.
              • shiyab
                • Sep 2023
                • 1676
                • india
                #867
                hi try
                • YOUN
                  • Feb 2015
                  • 89
                  • Burkina faso
                  #868
                  good morning ; i need to clean me my bios ;i have problem to boot
                  • YOUN
                    • Feb 2015
                    • 89
                    • Burkina faso
                    #869
                    LA K491P REV 2.0 SERVICE TAG 1DP5D3
                    • LBTT1121
                      • Nov 2024
                      • 1216
                      • Việt Nam
                      #870
                      bios backup error
                      • Alberto Martínez
                        • Aug 2025
                        • México
                        #871
                        Hello everyone
                        I'm having a problem. While updating my laptop's BIOS, it became corrupted and won't exit recovery mode. I already purchased the CH341A reprogrammer and installed the program and drivers.
                        I verified that it was working correctly, read the chip, and backed up the version I had, but now I can't reprogram the correct version. The files are larger than the chip supports. I have a Winbond 25Q80DVSIG chip, and it appears to be 8 MBits.
                        Could someone help me find the correct BIN file? Or, if so, tell me what I'm doing wrong.
                        Thank you very much.
                          • 22176
                          Originally posted by Alberto Martínez
                          Hello everyone
                          You chose the wrong chip. The 25Q80DVSIG is for the thunderbolt firmware or something else, it is not the bios chip.
                          • odtech
                            • Jul 2023
                            • 52
                            • South Africa
                            #873
                            Can someone please help with clean bios. Laptop starts but only caps lock light then keyboard backlight comes on then the laptop shuts down again.
                            Dell Latitude 5420 (Intel Core i5)
                            Motherboard GDF40 LA-K491P
                            Rev: 2.0(A01)
                            P137G001
                            Service TAG 7FB0MN3
                            Thanks in advance.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12423
                              #874
                              Rev: 2.0(A01)
                              P137G001
                              Service TAG 7FB0MN3
                              Thanks in advance.
                              Latitude 5420
                              Service Tag: 7FB0MN3
                              • odtech
                                • Jul 2023
                                • 52
                                • South Africa
                                #875
                                Originally posted by hoaca388
                                Latitude 5420
                                This file doesn't work. As long as I hold the power button the laptop fan will come on at max rpm but the laptop doesn't turn on.
                                Anything else to try with bios?
                                Thank you.
                                • odtech
                                  • Jul 2023
                                  • 52
                                  • South Africa
                                  #876
                                  Rev: 2.0(A01)
                                  P137G001
                                  Service TAG 7FB0MN3
                                  Thanks in advance.
                                  So I've been trying to redo this myself but FIT says my dump is corrupt. I then tried to build a new bin file from a Dell update but I can't get the update file extracted (As usual). I'm not sure if i'm doing something wrong or if the guide on here is outdated....?
                                  Any guidance or maybe someone able to try build a another bin file for me?
                                  • LBTT1121
                                    • Nov 2024
                                    • 1216
                                    • Việt Nam
                                    #877
                                    try and feedback
                                    • kamkooltech
                                      kamkooltech
                                      • Jun 2019
                                      • 132
                                      • nigeria
                                      #878
                                      good day everyone
                                      i need help
                                      a client brought a dell 5420 laptop to fixed, i saw the 32mb chip has be tamper and i have downloaded many files here and used, some could not worked, some worked but no image, only deem display, screen okay, signal cable okay,
                                      i still believed its bios issue because 5420 series are common series bios problem
                                      if any one experience same issues and solved please help me with working bios file.
                                      Board number: GDF40 LA-K491P REV 2.0
                                      ST: 5WJM2F3
                                      • peste
                                        • Dec 2016
                                        • 13809
                                        • ROMANIA
                                        #879
                                        Originally posted by kamkooltech
                                        good day everyone
                                        i need help
                                        ST: 5WJM2F3
                                        post the contents of the bios chip even if it is corrupted..
                                          • 22176
                                          good day everyone
                                          i need help
                                          ST: 5WJM2F3
                                          Did you save the original bios before trying others ? .If you did we can check if the service tag in the bios matches with the one you gave, and check if the configuration is ok. If you havn`t got the original bios then we can only assume that the service tag is right one, but the base cover might be from a different laptop.
                                          From the laptop configuration (see attached csv file) based on the service tag the CPU should be an i5-1145g7 - Tiger Lake. You can check the CPU part number to see if it is or not (somettime the motherboard model number will have the chipset name in it).
                                          Also from the configuration you will see it has non-vPro CSME firmware with ME disabled. There are more that 900 posts in this thread and there will be some bios with clean CSME/ME firmware matching that particular configuration.
                                          Use MEAnalyzer to check which bios versions have clean (Configured) firmware or not clean (Initialised) ,and look at the chipset support, if it says TGL it`s Tiger Lake, if it says CML it is Comet Lake. Obviously if you have a Tiger Lake CPU you
                                          don`t want to use a Comet Lake bios.
                                          • mirjana
                                            EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                            by mirjana
                                            I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                            The embedded controller is MEC5107-LJ (UE1).
                                            The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                            I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                            If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                            Thank you in advance!...
                                            07-16-2025, 12:55 AM
                                            DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-06-2024, 03:21 PM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            09-06-2024, 09:23 AM
                                            09-06-2024, 08:47 AM
