Hp gpt52 la-k201p bios
    Hello my friends
    To everyone who needs this file
    HP-GPT52 LA-K201P REV 1.0
    2020-09-18
    Mohammed Mohan
    Re: Hp-gpt52 la-k201p rev 1.0
    Originally posted by mohammed mohan View Post
    Hello my friends
    2020-09-18
    post the full name and model of the laptop.
      hi i want another bios for this laptop mb bc its not showing any m.2
        post the full name and model of the laptop, and your bios backup
          Re: gpt52 la-k201p bios REV 1.0
          Hi i have hp laptop
          model 15-dw3024nia
          MB CODE gpt52 la-k201p REV 1.0 i programmed it on hp software & Drivers now the laptop show led on motherboard then the led turn off and the fan never worked
            hp 15-dw3024nia gpt52 la-k201p rev 1.0 need bios
            Hi i have hp laptop
            model 15-dw3024nia
            MB CODE gpt52 la-k201p REV 1.0 i programmed it on hp software & Drivers now the laptop show led on motherboard then the led turn off and the fan never worked and i test this bios https://www.badcaps.net/forum/showthread.php?t=100530
            but the same thing happend with bios hp software & drivers
            i need bios for this laptop
              see post #4......
                Originally posted by SMDFlea View Post
                see post #4......
                hp notebook model 15-dw3024nia
                my laptop not working when i press power the button show led then the led of power turn off
                this is my bios
                  this is my bios
                  The file you posted is from the Lenovo Thinkpad T460S. Post the device's serial number.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    this is the sn CND1035XQ0
                      bios extracted from the HP site update..the laptop has seven variants of bios ..try them one by one ..
                        i tested all the bioses
                        0899F this is the one work on my laptop but the screen blink one and nothing came the fan spin the cpu warm
                          You have more hardware issue.
                            hp 15-dw3015cl bios
                            hi, i have a laptop hp 15-dw3015cl motherboard GPT52 LA-K201P, SERIAL CND10674V3 which cannot find the ssd when formatting windows. The SSD is however well recognized in the bios, I deactivated all the bios options but impossible to find it for training in W10.
                            I wanted to clean the original bios region but the software says it is corrupt or there is no region so I can't do it, can someone do it to me please?
                            searching here I found several bios but none work the pc does not turn on with the bios from this link: https://www.badcaps.net/forum/showth...ighlight=K201P
                            can you fix this original bios for me? THANKS
                              Re: hp 15-dw3015cl bios
                              I`ve merged your thread with this thread,why start a new one when you could have posted here.Everything you need to try and fix the bios yourself is already here and in sticky threads.
                              BIOS guides, methods, resources and tools
                              https://www.badcaps.net/forum/showpo...07&postcount=7
                              6.1.8. HP
                              https://support.hp.com
                              See: [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/showthread.php?t=122195 .
                              Your BID number is BID0881D. There`s a HP bios extraction guide
                              [Guide] How to extract ready for programming dump from HP update executable file
                              https://www.badcaps.net/forum/showthread.php?t=121948
                              No need though as peste has extracted and posted them at post #11
                              If the virgin bios doesn`t work youve got other hardware problems,or you should install the intel RST drivers during installation.If the bios does work then the next job is to transfer the DMI
                              from your backup and copy it to the new one using a hex editor, a 2 minute job. The offsets are 500000 - 501FFF .
                              By the way,i looked at the picture you posted,you`re using intel ME/TXE injector, i wouldn`t recommend using that -
                              How to clean ME/TXE region
                              https://www.badcaps.net/forum/showpo...41&postcount=3
                              Quote:
                              Do not use use Intel ME/TXE Injector/Easy Clean ME or similar tools: they do not retain the manufacturer's configuration and can cause subsequent problems.
                                6.1.8. HP
                                Sorry, I can't get any results, I can't find the firmware 15.0.2.1377 to clean the me region of my bios, can you help me?
                                  I tried with both methods (intel me txe and flash tool fit), I can't get any results, can you help me?
                                    Why waste your time.The virgin bios has fully configured clean ME firmware, all you have to do is copy your DMI to it from your backup, job done.If it doesn`t boot with the virgin bios you got bigger problems.
                                      I'm not a BIOS expert, I don't understand, what blank bios are you talking about?
                                      I found bios on the HP site, but in executable format, I didn't find any in bin format, the bios here in this page don't work for me, my original bios works it just has a problem recognizing the ssd, that's why I would like to clean the region, but I can't
                                      I don't know how to copy the DMI and where to find a blank bios, that's why I'm asking for your help
                                        Your serial number ?
