Bangho bes-1308
  • el panke
    • May 2019
    • 78
    • argentina
    Bangho bes-1308
    im looking for help with this one, its locket with password and couldn't find another file for this motherboard
    mother model 6-71-w13e0-d02 (w130exmb-0D)
    thanx in advance
  • Ghamidi
    • Mar 2020
    • 303
    • France
    Re: Bangho bes-1308
    thanx in advance
    try...
    • onizzbox
      Banned
      • Nov 2018
      • 604
      • Brazil
      Re: Bangho bes-1308
      thanx in advance
      Password: 41667555
      4 - four ( number )
      1 - one ( number )
      6 - six ( number )
      6 - six ( number )
      7 - seven ( number )
      5 - five ( number )
      5 - five ( number )
      5 - five ( number )
      In Laptop: Type the password and press <Enter>.
      • el panke
        • May 2019
        • 78
        • argentina
        Re: Bangho bes-1308
        Originally posted by Ghamidi
        try...
        tryed this one, still asking for password
        • el panke
          • May 2019
          • 78
          • argentina
          Re: Bangho bes-1308
          Originally posted by onizzbox
          Password: 41667555
          4 - four ( number )
          1 - one ( number )
          6 - six ( number )
          6 - six ( number )
          5 - five ( number )
          5 - five ( number )
          5 - five ( number )
          invalid, tryed with 2 diferent keyboard just in case
          • onizzbox
            Banned
            • Nov 2018
            • 604
            • Brazil
            Re: Bangho bes-1308
            @el panke
            try this,
            Password: rqyyuttt
              • 20984
              Re: Bangho bes-1308
              Post U27 backup if the passwod above doesn`t work.
              • el panke
                • May 2019
                • 78
                • argentina
                Re: Bangho bes-1308
                here u go buddy
                  • 20984
                  Re: Bangho bes-1308
                  try this bios
                  • el panke
                    • May 2019
                    • 78
                    • argentina
                    Re: Bangho bes-1308
                    try this bios
                    wont turn on with this one
                      • 20984
                      Re: Bangho bes-1308
                      I posted a virgin bios for a clevo W130EV ,thats what your backup is from,so maybe its the wrong one see the picture.
                      I found a bios on a "paid" site, "Clevo W130SV - 6-71-W13e0-D02 - W130ExMB-0D"
                      Try the W130SV bios here: https://repo.palkeo.com/clevo-mirror/
                      login username: repo
                      password: repo
                      The bios is 12MB it will need cutting into 8MB and 4MB using a hex editor.The bios is split accross 2 X chips. Do you have a chip at U32 already ?
                      • sikocan
                        Lenovo X1 Carbon 9th Gen Black Screen
                        by sikocan
                        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                        SN: PF3G1REP
                        MODEL: 20KW-00J1AU
                        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                        06-24-2025, 09:01 PM
                      • Devonavar
                        Vizio M43-C1 - How closely do I need to match the mainboard number?
                        by Devonavar
                        I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                        I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                        Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                        So, I've ruled out the PSU for now.
                        The reboot loop...
                        08-14-2022, 08:46 PM
                      • matyx
                        My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
                        by matyx
                        i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
                        Can somebody please help.
                        I dont know how to uplode the .bin file
                        02-20-2025, 02:26 PM
                      • esinior
                        Smd code to part number
                        by esinior
                        Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                        I've attached pics of this part
                        Thanks...
                        08-20-2024, 02:50 AM
                      • Friend33
                        Updating Serial Number on EliteBook x360 1030 G3
                        by Friend33
                        I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
                        Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
                        My serial number is: 5CD849BL7Q
                        FeatureByte:
                        3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
                        06-20-2024, 03:55 PM
