Asus GL753VD Need Bios
  • bilen
    • Aug 2014
    • 638
    • istanbul
    Please repair my orginal dump or clean me new dump share.. thank you.
    Motherboard code: GL753VD REV 2.0
    old dump:
  • lapfix
    • Mar 2020
    • 2720
    • my workshop
    Re: Asus GL753VD Need Bios
    old dump:
    Try repaired and clean
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Anchar777
      ASUS P1412CE need BIOS DUMP
      by Anchar777
      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
      06-26-2025, 03:39 AM
