Asus X540upr rev 2.0 Bios Repair
  • salawayon
    • Nov 2012
    • 578
    • philippines
    main issue no display problem:
    board info:
    X540upr rev 2.0
    i attached my backup... thanks
    • 21936
    Re: Asus X540upr rev 2.0 Bios Repair
    If there`s a white barcode sticker on the ram slot post a picture of it. its like the ones in this thread https://www.badcaps.net/forum/showthread.php?t=96604
    • erkant16
      • Aug 2017
      • 7
      • bursa
      The bios file is intact. I tried it on my own machine and got an image. There is another problem with your machine.Thank you.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • ferah831208
        help with bios decompose for Asus s5506ma
        by ferah831208
        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
        08-24-2025, 05:35 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • chudofermer
        Asus Ally rc71l bios
        by chudofermer
        Hello!
        Received Asus Ally rc71l with the wrong bios.
        Have the original package and all serial numbers.
        Can anyone help me understand what is wrong?
        Condition:
        Received with an original box with all serial numbers
        Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
        Got the flash dump, nothing found on DMI section
        No Windows key, just key ID on the box
        What is done:
        1. Flash the latest bios version with serial numbers...
        03-05-2025, 05:42 AM
