dell latitude 5310 password
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    #141
    Originally posted by matrixhrg
    please clear me
    Provide the full machine model number, serial number (or Service tag, SNID)
    • matrixhrg
      • Apr 2015
      • 11
      • Iran
      #142
      clear me
      dell latitude 5310 - M.B:19842-1
      Service Tag: DLDN403
      Last edited by Vesko356; 03-28-2024, 02:22 AM. Reason: Attached bios removed, already posted above.
      • Vesko356
        Vesko356 commented
        Editing a comment
        Read the rules before posting
        You MUST:
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • mrralvaroa
      • Feb 2021
      • 22
      Good Afternoon,
      Can someone help me unlocking this bios file and removing/disabling "Absolute" please.
      This is for a dell 5310
      System Number: DXPW203-8FC8
      Thank you, I appreciate the help.
      • minhdigital
        • Nov 2022
        • 758
        • Vietnam
        #144
        Originally posted by mrralvaroa
        Good Afternoon,
        Send to you
        • mrralvaroa
          • Feb 2021
          • 22
          Originally posted by minhdigital
          Send to you
          It worked, thank you so much.
          • stephan11
            • Apr 2024
            • 15
            • Deutschland
            #146
            Hello, can someone help me with this BIOS file reset and remove/disable “Absolute”. Dell Latitude 5310 2 in 1 Service Tag Number: 1G3B403 Thank you, I appreciate the help​
            • rex98
              • Feb 2023
              • 1280
              • Mandaue CEBU, Philippines
              #147
              1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
              if that doesn't work, put a bios password and read again and upload here. its easy to spot the hex offset with it.
              • stephan11
                • Apr 2024
                • 15
                • Deutschland
                #148
                When writing to the bois chip, an error message appears.
                  SMDFlea commented
                  Editing a comment
                  Erase the chip, program at a slower speed than 12Mhz
              • stephan11
                • Apr 2024
                • 15
                • Deutschland
                #149
                Thanks, it worked now. but "Absolute" is still active.
                Bios with password attached.
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  #150
                  try
                  • rex98
                    • Feb 2023
                    • 1280
                    #151
                    this is what i want 3 hex values needs to be changed. easy to spot with bios password.
                    try
                    • stephan11
                      • Apr 2024
                      • 15
                      • Deutschland
                      #152
                      "Absolute" is still active and grayed out.​
                      • m.sabry2110
                        • Oct 2017
                        • 129
                        • egypt
                        #153
                        try
                        • stephan11
                          • Apr 2024
                          • 15
                          • Deutschland
                          #154
                          Originally posted by m.sabry2110
                          try
                          Hello
                          “Absolute” still active​
                          • qayyum786
                            • Aug 2018
                            • 1933
                            • INDIA
                            #155
                            Hello
                            Try till you resolve the issue
                            • stephan11
                              • Apr 2024
                              • 15
                              • Deutschland
                              #156
                              Great, it worked, thank you very much.
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                #157
                                Finally unlocked +clean me worked for you
                                • Echoo
                                  • Apr 2018
                                  • 86
                                  • Budapest
                                  #158
                                  Hello!
                                  Can someone help me remove the bios password?
                                  Latitude 5310
                                  Service Tag: 8QRZ563​
                                  • volinakis
                                    • Jan 2021
                                    • 2741
                                    • N/A
                                    #159
                                    Originally posted by Echoo
                                    Hello!
                                    Latitude 5310
                                    try
                                    • Echoo
                                      • Apr 2018
                                      • 86
                                      • Budapest
                                      #160
                                      Originally posted by volinakis
                                      try
                                      Thank you very much for your work! It turned out perfect!
