dell latitude 5310 password
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    #141
    Originally posted by matrixhrg
    please clear me
    Provide the full machine model number, serial number (or Service tag, SNID)
    • matrixhrg
      • Apr 2015
      • 11
      • Iran
      #142
      clear me
      dell latitude 5310 - M.B:19842-1
      Service Tag: DLDN403
      Last edited by Vesko356; 03-28-2024, 02:22 AM. Reason: Attached bios removed, already posted above.
      • Vesko356
        Vesko356 commented
        Editing a comment
        Read the rules before posting
        You MUST:
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • mrralvaroa
      • Feb 2021
      • 21
      Good Afternoon,
      Can someone help me unlocking this bios file and removing/disabling "Absolute" please.
      This is for a dell 5310
      System Number: DXPW203-8FC8
      Thank you, I appreciate the help.
      • minhdigital
        • Nov 2022
        • 718
        • Vietnam
        #144
        Originally posted by mrralvaroa
        Good Afternoon,
        Send to you
        • mrralvaroa
          • Feb 2021
          • 21
          Originally posted by minhdigital
          Send to you
          It worked, thank you so much.
          • stephan11
            • Apr 2024
            • 14
            • Deutschland
            #146
            Hello, can someone help me with this BIOS file reset and remove/disable “Absolute”. Dell Latitude 5310 2 in 1 Service Tag Number: 1G3B403 Thank you, I appreciate the help​
            • rex98
              • Feb 2023
              • 1235
              • Mandaue CEBU, Philippines
              #147
              1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
              if that doesn't work, put a bios password and read again and upload here. its easy to spot the hex offset with it.
              • stephan11
                • Apr 2024
                • 14
                • Deutschland
                #148
                When writing to the bois chip, an error message appears.
                  SMDFlea commented
                  Editing a comment
                  Erase the chip, program at a slower speed than 12Mhz
              • stephan11
                • Apr 2024
                • 14
                • Deutschland
                #149
                Thanks, it worked now. but "Absolute" is still active.
                Bios with password attached.
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  #150
                  try
                  • rex98
                    • Feb 2023
                    • 1235
                    #151
                    this is what i want 3 hex values needs to be changed. easy to spot with bios password.
                    try
                    • stephan11
                      • Apr 2024
                      • 14
                      • Deutschland
                      #152
                      "Absolute" is still active and grayed out.​
                      • m.sabry2110
                        • Oct 2017
                        • 129
                        • egypt
                        #153
                        try
                        • stephan11
                          • Apr 2024
                          • 14
                          • Deutschland
                          #154
                          Originally posted by m.sabry2110
                          try
                          Hello
                          “Absolute” still active​
                          • qayyum786
                            • Aug 2018
                            • 1933
                            • INDIA
                            #155
                            Hello
                            Try till you resolve the issue
                            • stephan11
                              • Apr 2024
                              • 14
                              • Deutschland
                              #156
                              Great, it worked, thank you very much.
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                #157
                                Finally unlocked +clean me worked for you
                                • Echoo
                                  • Apr 2018
                                  • 77
                                  • Budapest
                                  #158
                                  Hello!
                                  Can someone help me remove the bios password?
                                  Latitude 5310
                                  Service Tag: 8QRZ563​
                                  • volinakis
                                    • Jan 2021
                                    • 2616
                                    • N/A
                                    #159
                                    Originally posted by Echoo
                                    Hello!
                                    Latitude 5310
                                    try
                                    • Echoo
                                      • Apr 2018
                                      • 77
                                      • Budapest
                                      #160
                                      Originally posted by volinakis
                                      try
                                      Thank you very much for your work! It turned out perfect!
                                      • diamon
                                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                        by diamon
                                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                        Pictures of these boards:
                                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                        Dell...
                                        02-28-2024, 12:51 PM
                                      • iwu
                                        Dell Latitude 5520 - dump bios to obtain password
                                        by iwu
                                        I am not experienced in electronics, but I really want to check if my idea is possible.
                                        I have motherboard replaced from Dell Latitude 5520 (11th gen on i5 CPU).
                                        BIOS/UEFI access on that MB/PC is blocked by password which I want to get it know - even if I need some bruteforcing or stupid manual activities.
                                        There was no computrace activated.
                                        I was happy when I saw many posts about removing BIOS password based on .bin file dummps. I wanted to go little further - get to know the password from the dump.
                                        1. I do not know how thebios...
                                        04-14-2024, 04:10 AM
                                        DELL Vostro 5310 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Vostro 5310 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5310 boardview and 5310 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 5310 Notebook...
                                        09-07-2024, 03:40 AM
