Lenovo Ideapad S145-15IIL BIOS
  • linxz
    • Dec 2016
    • 24
    I need bios for lenovo S145-15 IIL, nm-c171 rev 1.
    Thank you so much
    • 20977
    Re: Lenovo Ideapad S-145-15IIL BIOS
    Thank you so much
    Post your backup in a zip or rar .
    • linxz
      • Dec 2016
      • 24
      G'day mate,
      thank you,attached backup bios.BIOS Version is DKCN53WW,EC Version is DKEC24WW.Which IC for EC?How can i get out EC? please help.thank you so much!
      • pooya_pm
        • Jan 2021
        • 254
        • iraq
        g'day mate,
        thank you,attached backup bios.bios version is dkcn53ww,ec version is dkec24ww.which ic for ec?how can i get out ec? Please help.thank you so much!
        plz test
        • linxz
          • Dec 2016
          • 24
          Originally posted by pooya_pm
          plz test
          Thank you.I will test it tomorrow.
          • linxz
            • Dec 2016
            • 24
            plz test
            Thank you man,I tested ,booting can't detected HHD.would you please help me to fix Other Bios.thank you so much!
              • 20977
              G'day mate,
              Try this one.Virgin bios extracted from DKCN53WW update.
              For these models:
              IdeaPad S145-14IIL/XiaoXin-14IIL QC 2019/Lenovo IdeaPad S145-15IIL/Lenovo IdeaPad 340C-15IIL/V-14IIL/V-15IIL/BS145-15IIL
              DMI 622000 - 623FFF
              • linxz
                • Dec 2016
                • 24
                For these models:
                DMI 622000 - 623FFF
                Thank you Master!
                what is DMI meaning?
                I'm try it,SSD detected,when run windows going to frozen,may be have other problems?
                  • 20977
                  DMI is the serial number, UUID etc. Other problems i think .
                  • linxz
                    • Dec 2016
                    • 24
                    Thank you master,
                    I trying go to Windows safe mode,running is fast,no frozen.but s/n from PF1V3F51 TO PF1V3F6W.can go to windows some times,but frozen later.would you please analysis it what's problem?thank you!
                    • warsztat
                      • Feb 2017
                      • 190
                      • Polska
                      Need bios Lenovo IdeaPad S145-15IIL
                      Hello, I need a bios for Lenovo IdeaPad S145-15IIL, GS44D / GS54D NM-C711 Rev: 1.0 board, after pressing the power button the led only blinks, nothing else. I did a bios memory dump.
                      https://www.badcaps.net/forum/attach...1&d=1634826085
                      reagards
                        • 20977
                        Re: Need bios Lenovo IdeaPad S145-15IIL
                        reagards
                        Use the bios at post #7 ,copy your DMI from your backup to the new one with a hex editor, using the offsets provided
                        DMI 622000 - 623FFF
                        • warsztat
                          • Feb 2017
                          • 190
                          • Polska
                          DMI 622000 - 623FFF
                          Very good, thank you. All work ok.
                          • el panke
                            • May 2019
                            • 78
                            • argentina
                            Re: lenovo IdeaPad S145 bios needed
                            any1 culd help me with this one?
                            ideapad 145-15IIL
                            motherboard GS44D/GS54D nm-C711
                            rev:1.0
                              • 20977
                              ideapad 145-15IIL
                              rev:1.0
                              Your bios is version DKCN**** ,you can use the bios at post #7 ,its a virgin bios extracted from the lenovo update.You will lose DMI (serial number etc) so you need to copy the DMI from your backup to the new bios. The DMI area starts with the word LENV .I have posted the offsets that you need to copy,using a hex editor. If you don`t know how to use a hex editor i posted a small guide,and although its for a different model it will get you used to using the software and help to understand what the offsets mean https://www.badcaps.net/forum/showthread.php?t=98038 .If you can follow the guide to the end you should have no problem adding your DMI
                              • bogdan039
                                • Dec 2018
                                • 59
                                • Romania
                                hello.
                                please fix my original dump bios from lenovo,it die after bios update.
                                with dump bios from post no 7 i dont have ssd in bios setup and stuck on logo.
                                thank you.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11787
                                  Originally posted by bogdan039
                                  hello.
                                  thank you.
                                  Your serial number ?
                                  • hardware1
                                    • Sep 2021
                                    • 2936
                                    • N/A
                                    hello.
                                    thank you.
                                    try this file and give feedback.
                                    all donations are welcome,
                                    • bogdan039
                                      • Dec 2018
                                      • 59
                                      • Romania
                                      [QUOTE=hoaca388;1169833]Your serial number ?[/QUOTE....]
                                      • bogdan039
                                        • Dec 2018
                                        • 59
                                        • Romania
                                        With this bios no video like my originsl bios.
                                        Please fix my bios.
                                        Thank you.
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          Today, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
