Lenovo Ideapad S145-15IIL BIOS
  • linxz
    • 24
    I need bios for lenovo S145-15 IIL, nm-c171 rev 1.
    Thank you so much
    • 21692
    Re: Lenovo Ideapad S-145-15IIL BIOS
    Thank you so much
    Post your backup in a zip or rar .
    • linxz
      • 24
      G'day mate,
      thank you,attached backup bios.BIOS Version is DKCN53WW,EC Version is DKEC24WW.Which IC for EC?How can i get out EC? please help.thank you so much!
      • pooya_pm
        • Jan 2021
        • 258
        • iraq
        g'day mate,
        thank you,attached backup bios.bios version is dkcn53ww,ec version is dkec24ww.which ic for ec?how can i get out ec? Please help.thank you so much!
        plz test
        • linxz
          • 24
          Originally posted by pooya_pm
          plz test
          Thank you.I will test it tomorrow.
          • linxz
            • 24
            plz test
            Thank you man,I tested ,booting can't detected HHD.would you please help me to fix Other Bios.thank you so much!
              • 21692
              G'day mate,
              Try this one.Virgin bios extracted from DKCN53WW update.
              For these models:
              IdeaPad S145-14IIL/XiaoXin-14IIL QC 2019/Lenovo IdeaPad S145-15IIL/Lenovo IdeaPad 340C-15IIL/V-14IIL/V-15IIL/BS145-15IIL
              DMI 622000 - 623FFF
              • linxz
                • 24
                For these models:
                DMI 622000 - 623FFF
                Thank you Master!
                what is DMI meaning?
                I'm try it,SSD detected,when run windows going to frozen,may be have other problems?
                  • 21692
                  DMI is the serial number, UUID etc. Other problems i think .
                  • linxz
                    • 24
                    Thank you master,
                    I trying go to Windows safe mode,running is fast,no frozen.but s/n from PF1V3F51 TO PF1V3F6W.can go to windows some times,but frozen later.would you please analysis it what's problem?thank you!
                    • warsztat
                      • Feb 2017
                      • 190
                      • Polska
                      Need bios Lenovo IdeaPad S145-15IIL
                      Hello, I need a bios for Lenovo IdeaPad S145-15IIL, GS44D / GS54D NM-C711 Rev: 1.0 board, after pressing the power button the led only blinks, nothing else. I did a bios memory dump.
                      https://www.badcaps.net/forum/attach...1&d=1634826085
                      reagards
                        • 21692
                        Re: Need bios Lenovo IdeaPad S145-15IIL
                        reagards
                        Use the bios at post #7 ,copy your DMI from your backup to the new one with a hex editor, using the offsets provided
                        DMI 622000 - 623FFF
                        • warsztat
                          • Feb 2017
                          • 190
                          • Polska
                          DMI 622000 - 623FFF
                          Very good, thank you. All work ok.
                          • el panke
                            • May 2019
                            • 78
                            • argentina
                            Re: lenovo IdeaPad S145 bios needed
                            any1 culd help me with this one?
                            ideapad 145-15IIL
                            motherboard GS44D/GS54D nm-C711
                            rev:1.0
                              • 21692
                              ideapad 145-15IIL
                              rev:1.0
                              Your bios is version DKCN**** ,you can use the bios at post #7 ,its a virgin bios extracted from the lenovo update.You will lose DMI (serial number etc) so you need to copy the DMI from your backup to the new bios. The DMI area starts with the word LENV .I have posted the offsets that you need to copy,using a hex editor. If you don`t know how to use a hex editor i posted a small guide,and although its for a different model it will get you used to using the software and help to understand what the offsets mean https://www.badcaps.net/forum/showthread.php?t=98038 .If you can follow the guide to the end you should have no problem adding your DMI
                              • bogdan039
                                • Dec 2018
                                • 65
                                hello.
                                please fix my original dump bios from lenovo,it die after bios update.
                                with dump bios from post no 7 i dont have ssd in bios setup and stuck on logo.
                                thank you.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12281
                                  Originally posted by bogdan039
                                  hello.
                                  thank you.
                                  Your serial number ?
                                  ​https://www.badcaps.net/donate
                                  • hardware1
                                    • Sep 2021
                                    • 2946
                                    • N/A
                                    hello.
                                    thank you.
                                    try this file and give feedback.
                                    all donations are welcome,
                                    • bogdan039
                                      • Dec 2018
                                      • 65
                                      [QUOTE=hoaca388;1169833]Your serial number ?[/QUOTE....]
                                      • bogdan039
                                        • Dec 2018
                                        • 65
                                        With this bios no video like my originsl bios.
                                        Please fix my bios.
                                        Thank you.
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
