RCUnlocker
https://www.badcaps.net/donateComment
Re: RCUnlocker
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Every donation made will go towards server fees and maintenance costs.Comment
Re: RCUnlocker
Thx for your help
Its not working, software take my 16MB dump, but when flash into IC laptop is still require password on power on :/
Here both version of 16MB dump (original and updated with RCUnlocker).Last edited by SMDFlea; 04-01-2023, 01:44 PM.Comment
Re: RCUnlocker
Hello, i've been trying to get a dump of my bios using wson8 pogo pin probe and ch341a. After sticking the probe to the bios chip, the lights from the laptop powered on for a split second. After I assembled the laptop, POST error appears (is it because I removed CMOS battery? not sure) but the laptop boots fine. Now, do i need to disconnect all the connections from the board before using wson8 pogo pin probe or should I continue knowing the first scenario about laptop lights and possibly might short something?
And another problem, after I connected the battery, the laptop automatically powers on, is it normal?
Also after I put the back case, the caps lock stayed on for a few seconds and can only be booted by plugging the laptop from charger. Hopefully I did not damage my laptop.
Thank you for your help.Last edited by ogre4273; 09-25-2022, 03:00 PM.Comment
Re: RCUnlocker
remove the bios chip from the motherboard before reading or writing the bios chip, don't use the probe otherwise you might have errors... if you don't have an adapter socket for bios chips stick the bios chip on the programmer, or wires between the chip and programmer.. the laptop starts without pressing the ON button because you removed the bios battery..Hello, i've been trying to get a dump of my bios using wson8 pogo pin probe and ch341a. After sticking the probe to the bios chip, the lights from the laptop powered on for a split second. After I assembled the laptop, POST error appears (is it because I removed CMOS battery? not sure) but the laptop boots fine. Now, do i need to disconnect all the connections from the board before using wson8 pogo pin probe or should I continue knowing the first scenario about laptop lights and possibly might short something?
https://www.youtube.com/watch?v=DWWigscuQDYDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: RCUnlocker
thank you for your reply, now I can't boot my laptop. The charging led is blinking orange and white and the caps lock is blinking with long durations and whenever I put on the battery, it automatically turns on. What should I do now? any help please.remove the bios chip from the motherboard before reading or writing the bios chip, don't use the probe otherwise you might have errors... if you don't have an adapter socket for bios chips stick the bios chip on the programmer, or wires between the chip and programmer.. the laptop starts without pressing the ON button because you removed the bios battery..
https://www.youtube.com/watch?v=DWWigscuQDYLast edited by ogre4273; 09-26-2022, 03:40 AM.Comment
Re: RCUnlocker
So after some research, and as staded in my first post, the 32MB Main BIOS also need to be hex modify to be able to remove password on-power start.
I download couple of old and modify bit to understand what member modify, without succefully finding a method to remove it.
Can somebody lead me what should I modify to remove this dump "on-power password" that why customer don't set, and witch even HP with warrenty won't take it and ask ridiculous price to fix it ...Comment
Re: RCUnlocker
Hey do you know if it can also work to remove user password for "power on authentication" ?
Maybe I do thing wrong, but same as Smiler, tool work and say unlocked, but power-on authentication is still there, can't acces bios to reset, so still stuck
Same laptop as Smiler, G7 830Comment
Re: RCUnlocker
Give this a try, flash only 32MB file, leave the 16MB untouched. And leave feedback if it worked.
						Last edited by SMDFlea; 04-01-2023, 01:44 PM.I don't provide help for people using CH341A and a clip.Comment
Re: RCUnlocker
First test, working fine, I don't want to reset security setting as I fear windows won't launch anymore, i gonna rebuild laptop and edit to tell if it boot into windows.
Edit : No need to reset security setting, boot into windows just fine
Thx a lot DanielDacko and RethoricalCheese for your awesome toolLast edited by sadenki; 09-30-2022, 07:48 AM.Comment
Re: RCUnlocker
Glad to hear that it works, not done by RCUnlocker as it doesn't support 32Mb files.I don't provide help for people using CH341A and a clip.Comment
Re: RCUnlocker
Big news, customers came in, try 3 times is windows password, couldn't find it, reboot twice, and TADAAA, power-on security kick in.First test, working fine, I don't want to reset security setting as I fear windows won't launch anymore, i gonna rebuild laptop and edit to tell if it boot into windows.
So I gonna flash again with you modify bios, reset security and default setting, clean SSD, make a clean install and I should be fineComment
Re: RCUnlocker
yes.. you can write any bios version of the same laptop.. keep the original so you don't have problems.. and you can write it back when you want..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
			by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
							Channel: BIOS Requests ONLY!
			HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
			HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
			This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
 - Loading...
