RCUnlocker
  • DonZott
    • Apr 2014
    • 8
    • Belgium
    #321
    Re: RCUnlocker
    Hello RethoricalCheese,
    Amazing tool, I find the information display very usefull.
    I use it when i have a bios that is corrupt but still has the info about the system.
    This way I can read the info and use it to reprogram the laptop with a clean bios dump using wndmifit.
    Would it be possible to add a feature so it can write the info ( Model, Serial, Feature byte, COA, ...) to a text file? Or even better, to write that information to a clean bios dump?
    Kind regards and nice work
    • corona100
      • Mar 2020
      • 160
      • U.S.A
      #322
      Re: RCUnlocker
      RC unlocker need update not working with G6 on Hp
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #323
        Re: RCUnlocker
        It's easier to do it with uefitool.
        And about G6. What's the issue exactly? My hundreds of G6 unlock nicely.
        • onizzbox
          Banned
          • Nov 2018
          • 604
          • Brazil
          #324
          Re: RCUnlocker
          @RethoricalCheese
          Perhaps this is the request, although the MPM data is not required, depending on the model.
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #325
            Re: RCUnlocker
            Well yes, but there's no point in using it like that. You can just use uefitool to extract that region and then use uefitool again to replace it on a new bios.
            • onizzbox
              Banned
              • Nov 2018
              • 604
              • Brazil
              #326
              Re: RCUnlocker
              @RethoricalCheese
              Among some new generation models, after unlocking it is necessary to edit the MPM directly through the BIOS setup. This is the reason for the presentation of MPM in my patch.
              e.g HP 830 G8 EliteBook
              • tony stark
                • Aug 2017
                • 38
                • india
                #327
                Re: RCUnlocker
                can you share this tool..?
                • DonZott
                  • Apr 2014
                  • 8
                  • Belgium
                  #328
                  Re: RCUnlocker
                  Thanks for the response, i'm fairly new to Uefitool and editing bios files. Do you have any tips where I can find information/tutorial on how to find/extract that specific region and import it into a clean bios?
                  I was thinking of something that's more automated. If it is even possible.
                  I don't have any issues with G6.
                  Originally posted by onizzbox
                  @RethoricalCheese
                  That's indeed what I'm looking for. Is this something you made yourself?
                  It would be nice if there was a way to just export this into a clean bios file.
                  Kind regards
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #329
                    Re: RCUnlocker
                    Onizzbox, read again, it was not about unlocking.
                    DonZott, just check out uefitool. It's way easier than manually entering anything. Open your file and search for your SN, then you will see which section it is in. Super simple.
                    • anhbanxoi
                      • Sep 2021
                      • 182
                      • VN
                      #330
                      Re: RCUnlocker
                      Doesn't work on 32MB BIOS, HP Elitebook 830 G7
                        VIP Moderator
                        • Aug 2018
                        • 4387
                        • Bulgaria 🇧🇬
                        • Gadget & motorcycle addicted
                        #331
                        Re: RCUnlocker
                        Post the dump of the second bios chip.
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • anhbanxoi
                          • Sep 2021
                          • 182
                          • VN
                          #332
                          Re: RCUnlocker
                          I see only one BIOS chip
                          • onizzbox
                            Banned
                            • Nov 2018
                            • 604
                            • Brazil
                            #333
                            Re: RCUnlocker
                            @anhbanxoi
                            Haven't unlocked your laptop yet?
                            • anhbanxoi
                              • Sep 2021
                              • 182
                              • VN
                              #334
                              Re: RCUnlocker
                              @anhbanxoi
                              No I've done that laptop with your provided data & BIOS 32MB. Just wonder where is the 16MB chip and I found that one. There is 16MB IC near Nuvoton chip. So there are many ways to unlock this HP.
                              1. Via 32MB BIOS Chip and type all parameter
                              2. Via 16MB BIOS Chip
                              3. EC program via KB connector
                              Am I correct?
                              • DukeCrimson
                                • Jan 2022
                                • Singapore
                                #335
                                Re: RCUnlocker
                                Hello Everyone. I have a 830G6 laptop with BIOS password locked.
                                I have tried the following:
                                1) Desoldered the 16MB Winbond flash (25Q128) on the underside of the motherboard
                                2) Extracted the BIOS content from that chip and put it into RCUnlocker
                                3) Erase and wrote in the output from RCUnlocker into that chip
                                4) Soldered that chip back onto the motherboard
                                Here's where things become weird. Once I've reassembled the laptop and connected the battery (I haven't even attempted to turn on the laptop), the LED beside the charging port starts flickering (white/orange) and the "Caps Lock" button is lit. When I tried to turn on the laptop, nothing happens.
                                5) I have also tried repeating steps 1-4 on the 32MB Winbond flash (25Q256), but to no avail.
                                I have uploaded the files in the attached.
                                Any suggestions?
                                Thanks.
                                Regards,
                                Melvin.
                                • peste
                                  • 16533
                                  • ROMANIA
                                  #336
                                  Re: RCUnlocker
                                  Any suggestions?
                                  Thanks.
                                  Regards,
                                  Melvin.
                                  write the bios chips with the original content and see if it starts ..
                                  If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                                  It only takes 1 minute:
                                  https://www.badcaps.net/settings/subscriptions
                                  • DukeCrimson
                                    • Jan 2022
                                    • Singapore
                                    #337
                                    Re: RCUnlocker
                                    I've tried to write back the original contents into the BIOS chips, but the laptop still doesn't want to turn on =(
                                    Any other suggestions?
                                    • saidbe
                                      • May 2017
                                      • 42
                                      • Chilo
                                      #338
                                      Re: RCUnlocker
                                      Use raspberry pi and flashrom, find the sweetspot for read/write speed. Using a 3v3 LDO which gets power from USB might be needed for G3 to make it more reliable. Haven't tested this onboard on G3 yet.
                                      Make reading as fast as possible by specifying as narrow area as possible (for G3 it's the VSS region for example). Database needed for every model you might need unlocking.
                                      Make a python or bash script to make it all automatic (read, verify, patch, write, verify)
                                      In that case, all of it takes seconds. Maybe 10 or less, I haven't really measured time.
                                      Sorry that I am unable to share this part of the unlocker because I wrote it @ work Just to give you an idea, maybe somebody takes the time to make it happen.
                                      Oh and this is the whole reason I use raspberry. It's darn fast and reliable and makes automation possible. Awful for beginners tho.
                                      Can you please explain Raspberry Pi to SOIC Clips Wiring Diagrams?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12710
                                        #339
                                        Re: RCUnlocker
                                        See here
                                        https://www.youtube.com/watch?v=L35AD0LS70g
                                        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                                        Subscribe to support us. It only takes 1 minute:
                                        • saidbe
                                          • May 2017
                                          • 42
                                          • Chilo
                                          #340
                                          Re: RCUnlocker
                                          thanks
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                          • Boardview and Schematic Bot
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
