RCUnlocker
  • heatorious
    • Apr 2020
    Re: RCUnlocker
    Hi i was using the program and it seems its still locked after flashing the new file and following the steps.. please advise for this model Chromebook x360 11 g3 EE
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #342
      Re: RCUnlocker
      Then also reinstall OS
      • heatorious
        • Apr 2020
        Re: RCUnlocker
        okay thank you
        • kba81
          • Mar 2022
          • 8
          Re: RCUnlocker
          This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
          Unlocking
          HP - ProBook, EliteBook, ZBook (including 32MB models)
          Chromebooks from all various manufacturers
          Apple - everything older than T2
          More to come...
          Information display (helps to verify file integrity)
          HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
          Custom logo removal
          Usage: Drag and drop .bin file to .exe file.
          In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
          You may ask for feature requests, I'll see what I can do.
          I wanted to unlock 32mb dump from W25q256 (HP 820 G5) but RCunlocker seems to be unable to do it.Any chance you could update it?
          Please, have a look the image in attachements.
          I`m uploading also the original locked dump file.
          • peste
            • 13059
            • ROMANIA
            #345
            Re: RCUnlocker
            the program tells you that you missed the chip, and that you have to try on the 16 MB chip ... so look for a 16 MB chip on the board and use the program there.
            • kba81
              • Mar 2022
              • 8
              Re: RCUnlocker
              Thanks for the tip.You are right.On another side of the mobo I found another one:
              ISSI IC25LP128 QKLE.The problem I`ve got now is my programmer(EZP2019+) which seems do not support this kind of chip.What hardware I should use to read the chip?
              Thank you.
              • peste
                • 13059
                • ROMANIA
                #347
                Re: RCUnlocker
                Thank you.
                I did not use this type of programmer .. try to insert the chip manually or choose from the list an equivalent chip ... maybe someone else can help you more ..
                • volinakis
                  • Jan 2021
                  • 2766
                  • N/A
                  #348
                  Re: RCUnlocker
                  successfully unlocked HP 745 G5. It has 2 chipsets 25q128jv marked U365 and U366, the content of U366 has to be modified with RCUnlocker.
                  Thank you.
                  • Diesalweasel
                    • May 2016
                    • 49
                    #349
                    Re: RCUnlocker
                    Hi tried to unlock this hp elitebook 830 g7 with the rc unlocker and it tells me wrong chip try reading and unlocking 16mb chip. the file size is 32mb and it come from the chip located next to the cpu which is MX25L25673G . im slightly confused . i can only assume it me where the issue is .
                    best wishes
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11956
                      #350
                      Re: RCUnlocker
                      best wishes
                      Find other 16MB SPI chip on your mainboard.
                      Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
                      • dammysholove
                        • Jun 2017
                        • 59
                        • nigeria
                        #351
                        Re: RCUnlocker
                        Error
                        Rcunlocker showing error
                          • 21293
                          Re: RCUnlocker
                          Originally posted by dammysholove
                          Error
                          The instructions how to use it are at post #1
                          • juntmeako
                            NOOB
                            • Jul 2020
                            • 67
                            • na
                            #353
                            Re: RCUnlocker
                            can i use tge tool to remove SWAT?
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #354
                              Re: RCUnlocker
                              Swat?
                              • juntmeako
                                NOOB
                                • Jul 2020
                                • 67
                                • na
                                #355
                                Re: RCUnlocker
                                Swat?
                                yes, SWAT, mostly hp
                                • juntmeako
                                  NOOB
                                  • Jul 2020
                                  • 67
                                  • na
                                  #356
                                  Re: RCUnlocker
                                  SWAT security locked, anti teft enabled
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    #357
                                    Re: RCUnlocker
                                    Repeating the same word is of no help
                                    Give us a picture or something.
                                    • juntmeako
                                      NOOB
                                      • Jul 2020
                                      • 67
                                      • na
                                      #358
                                      Re: RCUnlocker
                                      here is rhe picture, image not mine.
                                      • deleted
                                        • Feb 2022
                                        • 10
                                        • Philippines
                                        #359
                                        Re: RCUnlocker
                                        in this case you need to clean the bios and second chip unlock that would be success to unlocked
                                        • DonZott
                                          • Apr 2014
                                          • 8
                                          • Belgium
                                          #360
                                          Re: RCUnlocker
                                          I suppose this does not support HP Spectre PRO x360 G2? (DAY0DDMBAE0)
                                          Or am I doing something wrong?
                                          Bios dump attached.
                                          Kind regards
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
