RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #261
    Re: RCUnlocker
    So both main and EC are 32MB?
    If so then just upload it here. It kinda supports it but I had disabled it. Been too busy to write some code so I could enable it again. Can do it manually for now.
    • magictouch
      • Apr 2021
      • 108
      • united kingdom
      #262
      Re: RCUnlocker
      Originally posted by hoaca388
      thanks, i am trying to access developer mode but it is going to developer mode or not going to powerwash, what is the next step I need to do? it straight boots up and says connect to wifi.
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #263
        Re: RCUnlocker
        Log in and powerwash if you can. If not, go to devmode and then back to normal mode and then log in and powerwash. If it doesn't work then just use a premade USB stick to restore OS.
        • magictouch
          • Apr 2021
          • 108
          • united kingdom
          #264
          Re: RCUnlocker
          Sorry to be a pain, The Chromebook is not going in the developer mode, then how is it going to boot from USB?
          Regards
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #265
            Re: RCUnlocker
            Are you familiar with Chromebooks and how they can be reinstalled? Or what are you trying to do, how are you trying to do and what exactly happens when you are trying to do it? Can't see your machine so I have no idea where you are stuck at.
            • ymifdal
              • Jan 2022
              • 119
              • Morocco
              #266
              Re: RCUnlocker
              Thank you and here you go bro
              Both extracted are 32MB TOP and BOT
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #267
                Re: RCUnlocker
                Flash bottom chip only:
                Become a Badcaps supporter
                Thanks to all supporters.​
                • ymifdal
                  • Jan 2022
                  • 119
                  • Morocco
                  #268
                  Re: RCUnlocker
                  It worked! Thanks a lot
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #269
                    Re: RCUnlocker
                    It worked!
                    I know, I know
                    Thanks a lot
                    You're welcome.
                    • slightly_delayed
                      • Nov 2021
                      • 11
                      • NL
                      #270
                      Re: RCUnlocker
                      Originally posted by slightly_delayed
                      Thx - that's really good news, because they are not that "narrow" (space-limited)!
                      I'll give it a try over the weekend.
                      Will give feedback after that.
                      cu
                      Hi, didn't work out....
                      Shaky hands, clumsy soldering iron, narrow space...
                      Don't get fooled by the pic/image in post #259 - no "big copper"-spots, about 2cm2 with tiny space between prone to soldering shortcuts (easy- and frequently)...
                      I'm again looking for other solutions/approaches....
                      Sigh....
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #271
                        Re: RCUnlocker
                        Those are huge. You just need experience and better tools it seems.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11956
                          #272
                          Re: RCUnlocker
                          Sigh....
                          You need a smaller tip soldering iron and a flux type.
                          Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
                          • slightly_delayed
                            • Nov 2021
                            • 11
                            • NL
                            #273
                            Re: RCUnlocker
                            and
                            Thx RethoricalCheese and hoaca388
                            You're both right. Your advice is most welcome....
                            I'll try to use the copper-pads directly without soldering, have to cut the black top plastics from a SOIC8-clip, hopefully the pins' distances will be ok..
                            Will report back...
                            • Smiler
                              • Mar 2021
                              • 7
                              Re: RCUnlocker
                              Hi there. Trying to unlock 840r G4
                              there is 2 chips
                              Tried to patch 32mb one and it gives an error that file is too big.
                              Patched 16 MB one its says its unlocked but password is still there. please help
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #275
                                Re: RCUnlocker
                                there is 2 chips
                                Program both chips:
                                • Smiler
                                  • Mar 2021
                                  • 7
                                  Re: RCUnlocker
                                  Thank you a lot Vesko356, worked like a charm!
                                  another question is it possible to do 830 G7 10th gen Cpu?
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #277
                                    Re: RCUnlocker
                                    You're welcome.
                                    Yes, it is possible.
                                    • Smiler
                                      • Mar 2021
                                      • 7
                                      Re: RCUnlocker
                                      You're welcome.
                                      here is 2 dumps please, and thank you in advance
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #279
                                        Re: RCUnlocker
                                        Here you are:
                                        • slightly_delayed
                                          • Nov 2021
                                          • 11
                                          • NL
                                          #280
                                          Re: RCUnlocker
                                          and
                                          Will report back...
                                          So, I cut off the black plastics, leaving the 8 pins of the SOIC8-clip uncovered (did it carefully and slowly - not to break or cut the pins, too).
                                          Pins' spacings seem to be ok.
                                          Put a small piece of rubber/eraser between the legs of the clip - a little bit more than the WSONs 6mm in order to touch the copper-pads more exactly. Applied a rubberband over the spring of the clip in order to put some pressure to the pins contacting the copper-pads.
                                          According to my magnifying glass everything seems to be ok - every pin seems to be in contact with its copper-pad counterpart...
                                          But software can't detect (and read) the IC....
                                          I know it's a fragile "construct" (don't move, don't touch), maybe I could better fix the pins to the copper-pads with some wax?
                                          Any hints - apart from soldering it?
                                          TIA :-)
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
