RCUnlocker
  • skazide
    • Jul 2015
    • 142
    • morocco
    #381
    Re: RCUnlocker
    thanks for reply i installed c++ 32 it worked thanks
    • Nefilim
      • Nov 2010
      #382
      Re: RCUnlocker
      Tryin to figure out how to unlock my Elitebook x360 1040 G6... I've found the 32MB main BIOS (MX25L25673G) and dumped it, and the only other chip I can see on this board is a Winbond W25Q80DV (1MB Chip). RCUnlocker doesn't work on the 32MB Macronix, it tells me to flash the 16MB BIOS.. but unless it's a new type of chip I've never seen before... I don't see anything that could be a 16MB BIOS anywhere (I have of course looked on both sides).
      I used HPUnlocker on the 32MB chip and flashed it back but the BIOS PW is still there.
      I've compared the locked vs unlocked BINs in HxD and see that HPUnlocker removed the "userCred" area of the BIOS, and I also tried manualy removing the areas after the "nvramActive" text (@ 2 spots) as I've seen this from comparing other users files that have been uploaded here before and after... and after flashing that it boots but when i try to go into the bios by hitting f10 it reboots.. I honestly don't know enough about this to try much more than that at the moment in order to unlock it... so any help would be appreciated!
      Here's the original 32MB dump..
      edit: board is a L63009-601 in case that helps
        • 21293
        Re: RCUnlocker
        If you use the "Search this thread" and also the "Search" function and look for "1040 G6" youll find other members have posted their 16MB backup and unlocked succesfully using RCUnlocker/HP Unlocker. Where is that 16MB chip,i don`t know,its hiding somewhere
        Please read the rules and do not start another new thread...
        • Granola
          • May 2022
          • 7
          • France
          #384
          Re: RCUnlocker
          Originally posted by Aaronrepair
          ok i compared both of my original and your unlocked file, can you please compare them in Hexcmp.
          they are %100 the same. how can this solve the issue like this? i also tried that and got the same result.
          I think it will be better to use the "fc.exe" command on DOS (cmd.exe) command, like fc /b file_dump.bin file_dump_unlocked.bin
          Then, the terminal will show the difference of the two files!
          • Granola
            • May 2022
            • 7
            • France
            #385
            Re: RCUnlocker
            Originally posted by RethoricalCheese
            Lately I've seen a few 840 G5 die of excessive heat when unsoldering and soldering bios chip. Otherwise, no.
            Hello RethoricalCheese!
            You're right: yesterday, I did find easily the 32Mb main BIOS chip, unlockit with HPUnlocker, verify the files and the differences, write it back to the Windbond 25Q256 and test it (with long wire) => it work
            But admin password still there...
            Then "hoaca388" wrote on the HPUnlock related thread:
            "You have another 16MB or 32MB chip left. Look for it on both sides of the main board." => thats right, on the other side, the hidden one
            So, this morning, I tried to unsolder the ISSI IC25LP128 WON08 chip, with some difficult, because of the soldered middle pad on the back of the chip.
            Finally, when off, my TL866II said that the connection to the chip (1~3 and 5~7) are bad (pin errors) ==>> no way to read back the data
            My question: could anyone post an locked or unlocked 16Mb BIOS file (the EC chip) for an 840 G5 laptop?
            It could be very nice
            Thanks for your help!
            • Granola
              • May 2022
              • 7
              • France
              #386
              Re: RCUnlocker
              *** OK, FORGET IT ***
              Breaking News, finaly, when pulling the wire from the chip, I was able to read it... and soon after, did TWO backup of the locked EC bin file
              After droping the locked bin to the RCUnlocker executable, the unlocked file appear, and was immediately programmed to an SOIC Windbond 25Q128 (I had three pieces frm a previois chineese order ).
              Easy to solder that one, put all screw (minus two ??? ther left!) to mount the pcb, fan, keyboard... breath long time, and push the power button...
              Soon, I could go on the BIOS, no more annoying password, and reset the security settings, as said on post #1...
              A few reboot later, I came back to my Windows 11, setup the account password, (pin code), fingerprint and camera recognation..
              So, RethoricalCheese you did it well, and my 840G5 thank you to to get his full freedom!
              Kind regards
              • raduku2u
                • May 2022
                • ireland
                #387
                Re: RCUnlocker
                hey i have a hp elitebook 840g7 with a bios password how can i reset it ?i only get to try the password 3 times and after i need to reset laptop,i have the bin file that u posted but i have noidea what to do with it, please help
                • adom
                  • Sep 2021
                  • 12
                  • Switzerland
                  #388
                  Re: RCUnlocker
                  whenever i unlock the 840 g7 bios password i am missing the fingerprint driver
                  can someone help me? how do i get the fingerprint driver back?
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #389
                    Re: RCUnlocker
                    Does it work before unlocking?
                    I saw in your other topic that you used lbe++, when you use the RCUnlocker does it happen again?
                    Explain in more detail what you have done and what you want to get as a result to get the right direction.
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #390
                      Re: RCUnlocker
                      Did you reset security settings after unlocking?
                      • Montanatony
                        • May 2022
                        • france
                        #391
                        Re: RCUnlocker
                        hi friend it works for 1030 g3 bios pass locked ?
                        • peste
                          • 13059
                          • ROMANIA
                          #392
                          Re: RCUnlocker
                          read first page ...
                          • Markus1741
                            • Sep 2020
                            • 866
                            • N/A
                            #393
                            Re: RCUnlocker
                            Hello, what a shame what am I doing wrong.
                            I always get this error message when I open the RCUnlocker in Windows 10 64bit.
                            Also by drag and drop. Maybe someone knows a solution.
                            Thanks in advance
                            • peste
                              • 13059
                              • ROMANIA
                              #394
                              Re: RCUnlocker
                              Thanks in advance
                              do not open RCUnlocker ... drag the bios into RCUnlocker from the folder ..
                              • nad&a servis
                                • Sep 2019
                                • 6
                                • Fier
                                #395
                                Re: RCUnlocker
                                Hello! How does this program work?
                                • peste
                                  • 13059
                                  • ROMANIA
                                  #396
                                  Re: RCUnlocker
                                  you do not have the password on this chip ... look for another chip on the board ..
                                  • Markus1741
                                    • Sep 2020
                                    • 866
                                    • N/A
                                    #397
                                    Re: RCUnlocker
                                    Sorry drag and drop same error message.
                                    • hpboy
                                      • Jan 2021
                                      • 53
                                      Re: RCUnlocker
                                      For anyone who is having trouble using this amazing utility from @RethoricalCheese here is a full video guide using the utility on a HP ProBook:
                                      Full Video - https://www.youtube.com/watch?v=QnlvlKuPMVk
                                      RCUnlocker Section of video - https://youtu.be/QnlvlKuPMVk?t=558
                                      • Veddel%
                                        • Jan 2022
                                        Re: RCUnlocker
                                        Hello.
                                        I download the "RC unlocker".ok. Then i want open it and it display a message to donate some money.
                                        Now, how i can open this file?
                                        Regards Detlef
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11959
                                          #400
                                          Re: RCUnlocker
                                          Originally posted by Veddel%
                                          Hello.
                                          I download the "RC unlocker".ok. Then i want open it and it display a message to donate some money. I send 5 € with paypal to Rethorical Cheese.
                                          Regards Detlef
                                          Do not open that file
                                          Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
