ms-15621 bios dump
  • nassih
    • Oct 2015
    • 276
    • morocco
    ms-15621 bios dump
    hi everyone i need bios dump for this laptop msi(no model) motherboard ms-15621,
    the laptop can turn on ,only the processor fan turn on ,graphics fan no,
    i have communication on bios pin 6 (oscilloscope signal)i don't have schematic for this motherboard
  • peste
    • Dec 2016
    • 12768
    • ROMANIA
    Re: ms-15621 bios dump
    post the backup of the original bios
    • nassih
      • Oct 2015
      • 276
      • morocco
      ok
      • peste
        • Dec 2016
        • 12768
        • ROMANIA
        ok
        try.this..
        https://www.msi.com/Laptop/support/Stealth-15M-A11SDK
        • nassih
          • Oct 2015
          • 276
          • morocco
          ok i will try tanks sir
          • nassih
            • Oct 2015
            • 276
            • morocco
            it doesn't work it turns on and goes off immediately.the file is not in .bin format ?
              • 20844
              just rename it from E1562IMS.114 to E1562IMS.BIN .Open it with a hex editor and check it,its the full bios ,whichever way its named.
              Post the full laptop model number
              • nassih
                • Oct 2015
                • 276
                • morocco
                i already did it, rename the file to .bin
                I don't have the laptop model
                • Zhuravlev.m3
                  • Mar 2014
                  • 5
                  • Ukraine
                  Hello. please help me to remove bios password. original dump attached. Thanks
                  • peste
                    • Dec 2016
                    • 12768
                    • ROMANIA
                    admin password 444333
                    boot password 333444
                    • Zhuravlev.m3
                      • Mar 2014
                      • 5
                      • Ukraine
                      Thanks. everything is working
                      • olteandan
                        • Oct 2018
                        • Romania
                        ok
                        Thank you , it worked
                        • glovecaps
                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                          by glovecaps
                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                          11-25-2024, 04:23 PM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • DynaxSC
                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                          by DynaxSC
                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                          11-06-2022, 05:22 PM
                        • TacticalFahrrad
                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                          by TacticalFahrrad
                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                          06-30-2025, 04:09 AM
                        • vinaypundith
                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                          by vinaypundith
                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                          08-03-2024, 12:32 PM
