bios for lenovo ip 3 15IIL05 GS454/GS554/GV450/GV550 NM-D031
Every donation made will go towards server fees and maintenance costs. -
Re: bios for lenovo ip 3 15IIL05 OR GS454/GS554/GV450/GV550 NM-D031
Need Bios
IdeaPad 3 14iiL05
Model Name: 81WD
SN: PF2C30DP
Motherboard Code:
NM-D031 Rev. 1,0
2019-12-06
Problem: No Power
19v. 5v. 3v are all present
bios backup fileAttached FilesComment
try
extracted from lenovo supportComment
can someone help me repair my bios,,
GS454/GS554/GV450/GV5550
NM-D031 REV1.0Attached FilesComment
​https://www.badcaps.net/donateComment
Here's your new file, try it and let me know.
Always remember to write your device serial number to confirm the exact model.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
WorksAttached is a virgin bios extracted from the lenovo update.Open your backup bios and virgin bios with a hex editor.Copy your DMI from your backup using the off-sets in the picture and paste-insert into the virgin bios ,using the same off-sets and save it.
HxD hex editor https://mh-nexus.de/en/hxd/
Onboard ram disabled bios need for nm-d031 rev 1.0Attached FilesComment
Try this file and let me know.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
its work no sn full clearAttached FilesComment
You have a bios for ideapad 3 15iil05 10 gen
sn: Pf2k13wa modelo name: 81we
i add the old bios NO VIDEO AND FLASHING BLOCK MAYUSAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Hi guys,
just fixed some issue with this board, but now my bios look Corrupt if anyone can help me (on startup Power Lid blinking non stop)
Ideapad 3 15IIL05
model: 81we
s/n: PF2EPB9T MTM: 81WE00DDCC
Factory id: GXSCAttached FilesLast edited by alphine; 01-26-2023, 06:17 PM.Comment
you can find everything you need in this thread...you just have to search and read...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
nm-d031 no display power light blinkingAttached FilesComment
by vremHi all,
i have ideapad 3 15iil05 board gs454/gs 554/gv 450/gv 550 nm-d031,
someone can help me to disable onboard ram?
is possible just swap resistor?
here board pic
thank in advance for any help... -
by yaso143gs454/gs554/gv450/gv550 nm-d031
can anyone help ?
first issue short in main power rail fixed by replacing a mosfet
new issue
unit turns on after 5 seconds it turns off (when battery is plugged)
unit turns on then off immediately(when batt is unplugged and using charger only)
main power rails are present 20v , 3.3v is present 5v is present 1.8v is present when unit is turned on 1.8v shows then disappear when unit shuts itself down
also i noticed that cpu is getting hot then turns off
do you have...
by kalilinux25LAPTOP: IDEAPAD 3 14IIIL05
MODEL NAME: 81WD
SERIAL NUMBER: PF2K713H
BAORD: GS454/GS554/GV450/GV550 REV 1.0 NM-D031 2019-12-06
PROCESSOR: i3-1005G1
GRAPHICS: NO GFX
ONBOARD RAM
ISSUE: NO DISPLAY
taking 30milliamp
ALW_PWRGD-3.1v on and off state
EC_RSMRST#- 3.0v
PCH_PWROK- 0v onstate and off state 9.9k ohms
PM_SLP_S3#- onstate 0v off state 0v
PCH_DPWROK-3.0v on state and off state
VCCST_PWRGD_R- 0v on/off state
+VCCIN_AUX -0.8v
+VCCIN- 0v
+1.8VALW_P- 1.5v... -
lenovo ideapad 3
laptop board info-
NM-D031
Rev:1.0
2019-12-06
please can I have a bios.bin to flash as a last hope to revive?-
Channel: BIOS Requests ONLY!
by Ardent1Hello everyone, I have never flashed a bios before and currently find myself needing to flash a new Winbond W25Q128JVSQ chip without the original bios file.. I have a CH341A programmer and have been able to connect the chip to neo-programmer, but that's about as far as my knowledge takes me so far. When i read the chip the data appeared to be all FF for every entry.
I do not know the history of the motherboard, only that the old chip was removed because it was dead apparently. When the on button is pressed, the laptop on battery alone just shows a solid white light on the side and same on...-
- Loading...
