BIOS for lenovo ideapad 3 NM-D031
  • m1ch43lzm
    • Mar 2019
    • 969
    • Peru
    #41
    Check for hardware problem
    • fabrix1
      • Oct 2025
      • 5
      • Argentina
      #42
      The problem is the internal memory, can you disable it?
      • LBTT1121
        • Nov 2024
        • 1068
        • Việt Nam
        #43
        try and feedback
        • fabrix1
          • Oct 2025
          • 5
          • Argentina
          #44
          Thank you so much! I installed the new BIOS and it worked! It displayed an image via HDMI but not on the screen. Actually, it did, but the screen didn't light up.
          • fabrix1
            • Oct 2025
            • 5
            • Argentina
            #45
            Originally posted by LBTT1121
            try and feedback
            Is there a solution through the BIOS? Or do I have to replace the screen?
            • LBTT1121
              • Nov 2024
              • 1068
              • Việt Nam
              #46
              try replace the screen
              • m1ch43lzm
                • Mar 2019
                • 969
                • Peru
                #47
                Do you have an image when you shine a flashlight to the screen? That means "no backlight" fault, check the backlight fuse FG3301 first, open a new thread in troubleshooting laptops section if you need help https://www.badcaps.net/forum/troubl...mobile-devices
                Schematics https://www.badcaps.net/forum/troubl...59#post1654359
                Common fault if the screen is disconnected before disconnecting the battery; unplug battery, measure continiuty across the fuse FG3301, if blown, replace it, 3A 32V 0402 size fuse
                • mkdj
                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                  by mkdj
                  Dear all,
                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                  Here the steps I have taken to fix the laptop:
                  - downloaded latest BIOS from Lenovo Website...
                  10-18-2025, 03:43 AM
                • jendkkd jeje
                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                  by jendkkd jeje
                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                  10-11-2024, 03:12 PM
                • joven016
                  Lenovo Ideapad S145 need working bios HELP!!
                  by joven016
                  Problem is blinking power led only
                  i don't know exactly if it's s145-15igm or s145-14igm
                  have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                  Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                  Already tested some of posted bios here
                  S145-14igm - success but invalid serial and not booting on OS
                  S145-15igm - success with serial and some other info in bios but still not booting on OS
                  already tried installing new windows but always booting on bios setup
                  windows installer flash drive detected on...
                  08-21-2025, 10:55 PM
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • mximiliandz
                  help bios lenovo ideapad s145-14iil type 81w6
                  by mximiliandz
                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                  06-20-2025, 06:50 AM
