Legion 5 15IMH05 Bios
    • 22084
    Re: Legion 5 15IMH05 Bios
    Originally posted by koby058
    Hi Gentlemens,
    please help with bios for this Legion 5 15IMH05H
    original attached
    S/N: PF2BZGEb
    Try the bios at post #2 ,copy your DMI (serial number etc) from your old bios to the new one using a hex editor, the off-sets are at post #3
    • koby058
      • Jan 2017
      • 387
      • israel
      Thanks, is there a guide on how to do that ?
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        See post #3.
        Become a Badcaps supporter
        Thanks to all supporters.
          • 22084
          There is a guide for a different bios,but it covers all the bases of simple hex editing. Once youve done that you should have no problem with your bios once you understand what the offsets are, its just copying from one region and pasting over the same region in another file.
          https://www.badcaps.net/forum/showthread.php?t=98038
          If you can`t do it let us know,i`ll post a macro script to do it automatically.
          • koby058
            • Jan 2017
            • 387
            • israel
            Thanks, i think i have done it well
            • ozzyfrozzy
              • Nov 2018
              • the netherlands
              #26
              Need Clean/Virgin Bios for Lenovo Legion 15-IMH05
              I need a clean bios to flash to the bios chip.
              Serial Number:PF2AY437
              Machine Type Model:82AU0031MH
              Legion 5-15IMH05
              Unfortanetely i dont have any old bios dump beceause someone wiped the bios chip. Laptop doesnt turn on right now so if someone can help me out with a clean bios.
              What i understand is you need DMI for Windows activation purposes. What only matters is that if the laptop turns on normally it will be fine.
              Hope you guys can help me out.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #27
                Re: Need Clean/Virgin Bios for Lenovo Legion 15-IMH05
                Legion 5-15IMH05
                Use the search engine, and read the rules.
                Thread merged.
                • qayyum786
                  • Aug 2018
                  • 1959
                  • INDIA
                  #28
                  Hi Gentlemens,
                  original attached
                  S/N: PF2BZGEb
                  extracted from lenovo support + dmi injected
                  • fazz_80
                    • Aug 2023
                    • Poland
                    #29
                    Lenovo Legion 5 15IMH05H Type 81Y6
                    Serial Number: PF22TB48
                    MTM: 81Y6005TUK
                    Could you put my DMI and do the ME with the data from my Laptop Lenovo Legion 5 15IMH05H ?
                    • minhdigital
                      • Nov 2022
                      • 765
                      • Vietnam
                      #30
                      MTM: 81Y6005TUK
                      Send to you !!
                      • fazz_80
                        • Aug 2023
                        • Poland
                        #31
                        Originally posted by minhdigital
                        Send to you !!
                        This BIOS is incorrect it does not contain the correct ME.
                        • peste
                          • 13721
                          • ROMANIA
                          #32
                          you have everything you need at the #15.post..
                          • ajyanz
                            • Sep 2017
                            • philippines
                            #33
                            Please help me, i check discrete gpu in bios then it goes no display. thanks in advance.
                            sn:PF23DP85
                            • FrozenHaxor
                              • Jun 2015
                              • 266
                              • Poland
                              #34
                              sn:PF23DP85
                              It's not a BIOS issue, your GPU core is dead.
                              • ajyanz
                                • Sep 2017
                                • philippines
                                #35
                                how can i reset the bios to set gpu to dynamic?
                                • FrozenHaxor
                                  • Jun 2015
                                  • 266
                                  • Poland
                                  #36
                                  Try connecting external display through HDMI and disconnect eDP connector, if it's routed through the CPU and not the GPU directly, you'll be able to enter BIOS and set the graphics to UMA only.
                                  Usually I would replace the dead GPU chip, but Lenovo is a menace and uses black underfill glue that ruins the board when trying to desolder the BGA chips. It's possible to get the glue debonded but it's not worth the effort, better to run that board in UMA or just replace it.
                                  • Sofian75
                                    • Aug 2023
                                    • 87
                                    • France
                                    #37
                                    I think I have a dead GPU on the board (reading 0 ohm)
                                    Is there a way to deactivate the GPU so I can rely on the iGPU to power up the laptop?
                                    I ve already lifted the 3 coils feeding the GPU, isn't that enough?
                                    Right now the laptop starts then shutdown.
                                    SN: PF2E6NV1
                                    MTM: 82AWCTO1WW
                                    PS: Please let me know if anything is wrong with my bios.
                                    • Sofian75
                                      • Aug 2023
                                      • 87
                                      • France
                                      #38
                                      SN: PF2E6NV1
                                      MTM: 82AWCTO1WW
                                      Never mind, just found that the cpu is shorted too, I didn't have a proper ground and got a wrong reading on the cpu.
                                      • magy
                                        • Nov 2022
                                        • poland
                                        #39
                                        Hello, I need the bios of a Lenovo Legion 5 15IMH05 NM-C921 rev 1.0, if anyone can help me I would greatly appreciate it.
                                          • 22084
                                          Thread merged. Post your bios backup and laptop serial number https://www.badcaps.net/forum/troubl...before-posting
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • grimacelord
                                            by grimacelord
                                            Hello there.
                                            History:
                                            03-15-2023, 03:29 PM
                                            Lenovo Legion 7 15IMH05 Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion 7 15IMH05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7 15IMH05 boardview and 7 15IMH05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 04:30 AM
                                          • faousi
                                            BIOS Legion C730
                                            by faousi
                                            Hello frends,
                                            I have an issue with this Computer. It doesnt boot, only fans are spining. I think I have a corrupted BIOS!
                                            So I have read an save BIOS from the chip with a ch341A programer.
                                            On the Lenovo driver site I have downlaoded the BIOS-Update but I cant extract the BIOS-Firmare to program the chip!
                                            Can someone help me!
                                            I have a
                                            Legion C730-19ICO Desktop (Lenovo) - Type 90JH
                                            Serielno. : S1011C9G​
                                            That is the Link to the lenovo BIOS:
                                            https://pcsupport.lenovo.com/de/de/p.../legion-c730-1...
                                            01-13-2025, 09:46 AM
