Dell Latitude 7300 8FC8 BIOS suffix dump, ST 177TQ13-8FC8. Have a look please and perhaps explain why W11P install from flash media fails every time. Thank you.
Dell 7300 locked bios
Hi, My laptop has bios password.
Dell Latitude 7300
S/T: 6LCS1Z2
Here is bios dump. Please unlock it.
Thanks,Comment
Send to youComment
Looking for help from the excellent and knowledgeable members of this forum to unlock two Dell Latitude 7300s with 8FC8 locks. STs 1RV13X2 and CHKY2Z2. BIOS dumps are attached. Thank you.
Unlocked↵
​https://www.badcaps.net/donateComment
Got several more locked Dell Latitude 7300s. Attached are dumps from two of them. Can someone please have a look and unlock? Dumps from two more coming shortly. Thank you.
And here are two more Dell Latitude 7300 BIOS dumps with 8FC8 locks. Thanks to all who make this such a great resource.Comment
Here:
1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing modeComment
Have a couple of 8FC8 locked Dell Latitude 7300s (STs 4MQ53X2 and GXHY2Z2; board P/N LA-G861P). Request unlock help. Dumps attached. Thank you.Comment
Hi can i help me to unlock bios for dell latitude 7300 bios password i need factory bios if has posibleAttached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing modeAttached FilesComment
Hello ME Clean + Unlocked your file ....
Good luck ....Attached FilesComment
Hi i need to unlock bios for Dell latitude 7300 if is posible i need clear bios bicose i have master password thnx
Service Tag :17FY633
Model Board :EDC30 LA-G861P REV:1.Attached FilesLast edited by Khaled Mohamed; 05-07-2024, 11:04 AM.Comment
Channel: BIOS Requests ONLY!
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
