HP ZBOOK 14U G6 Bios Password
  • Kodza
    • Jun 2016
    • 173
    • South Africa
    Hi guys I have hp Zbook 14U G6 with bios password and power on password, I have tried to remove the password using Hp unlock tool but failed. I hope some one can help remove the password. I have attached the files.
    Thanks in advance
  • peste
    • Dec 2016
    • 12240
    • ROMANIA
    Re: HP ZBOOK 14U G6 Bios Password
    Thanks in advance
    try..
    • Kodza
      • Jun 2016
      • 173
      • South Africa
      Thank you I will try and update you
      • Kodza
        • Jun 2016
        • 173
        • South Africa
        Thank you for the assistance it worked
        • True0Man
          • Aug 2021
          • Poland
          i have the same problem - i cant update my BIOS cause its asking for password.
          how should i use those .BIN files?
          thanks in advance for your help
          • Kodza
            • Jun 2016
            • 173
            • South Africa
            Hello guys I have a HP Zbook 14u G6 bios password. Please help clear, I have attached files
            • peste
              • Dec 2016
              • 12240
              • ROMANIA
              try..
              • Kodza
                • Jun 2016
                • 173
                • South Africa
                Thank you very much brother its working
                • mordred-2704
                  • Jan 2022
                  • netherlands
                  hi guys,
                  how do i need to use these bin files?
                  putting them on a usb stick and booting from file will does not work...
                  any advice is very much appreciated!
                  tnx !
                  • ibo
                    • Oct 2019
                    • 93
                    • Turkiye
                    Originally posted by mordred-2704
                    hi guys,
                    tnx !
                    you must read your bios chip first.
                    • justice171
                      • Feb 2018
                      • 101
                      • South Africa
                      HP ZBOOK 14u G6 BIOS UNLOCK
                      Good day,
                      Can someone please assist by unlocking this bin of Zbook 8th Gen the POST POWER-ON PASSWORD?
                      Please find attached Locked BIOS BIN
                      HP ZBOOK 14_Locked.zip
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11161
                        • Viet Nam
                        Re: HP ZBOOK 14u G6 BIOS UNLOCK
                        https://www.badcaps.net/forum/showthread.php?t=98539
                        Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
                        • justice171
                          • Feb 2018
                          • 101
                          • South Africa
                          Hello hoaca388, thank you for the link I downloaded the RC Unlock it says, "Wrong chip. Try reading and unlocking 16MB Chip and I'm running 32MB file"
                          Check the screenshot on the attachment
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11161
                            • Viet Nam
                            [ATTACH]256389[/ATTACH]
                            Try find 16MB chip on your mainboard. Your laptop have two bios chips.
                            • Kodza
                              • Jun 2016
                              • 173
                              • South Africa
                              Hello guys, I got HP Zbook 14u G6 which had bios password. I used RCunlocker to remove the password and I used the 16mb file but when I went to bios settings I saw that it had computrace so I tried to remove it with HP Unlocker with the 32mb file and after that I tested and the laptop did not respond so I took the unlocked file which I got from Peste from a previous laptop same model. I compared the 32mb files locked one and unlocked and saw where the difference and made the same changes which were made on those files to this one with computrace and it did not come on again. So I tried to put back the original file but still it doesn't want to come on, it's flashing the charger light amber white amber white for about 5 seconds and then the light turns orange and then after that nothing even if I leave it for some time. So I have attached both original files if anyone can help.Thanks
                              Last edited by Kodza; 04-18-2022, 11:24 AM. Reason: I pressed wrong button when I was typing
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11161
                                • Viet Nam
                                Is the 32MB file your original file?
                                • Kodza
                                  • Jun 2016
                                  • 173
                                  • South Africa
                                  Yes it is the original
                                  • Bsolution
                                    Banned
                                    • Oct 2021
                                    • 73
                                    • punjab
                                    no your 32dump not orignal
                                    • Kodza
                                      • Jun 2016
                                      • 173
                                      • South Africa
                                      Ok let me send you another copy I made
                                      • Kodza
                                        • Jun 2016
                                        • 173
                                        • South Africa
                                        Here is second backup file, it's the original file
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • snpetit
                                          Asus FA706IH Bios Password remove
                                          by snpetit
                                          i need some help :-/
                                          i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                          Could you please remove all password related stuff from this bios. A hate Asus....
                                          Thanks in advance!...
                                          01-10-2025, 09:17 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • beBoss
                                          HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                          by beBoss
                                          as noobie to this please excuse my lack of experience.
                                          I am trying to remove a BIOS password from this machine:
                                          HP ProDesk 400 G6 Mini
                                          but so far I still have no success.
                                          I bought CH341 programmer and decided to give it a try.
                                          The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                          I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                          05-30-2024, 12:48 PM
