dell latitude 5490 bios
  • DProf.
    • Jun 2018
    • 100
    • Nigeria
    Hello great engineers. Please I need bios dump for dell latitude 5490
    • 22105
    Re: dell latitude 5490 bios
    The latitude 5590,5490 and 5290 use the same bios . Check post #10 .https://www.badcaps.net/forum/showthread.php?t=67599
    • DProf.
      • Jun 2018
      • 100
      • Nigeria
      Pls if u have the password to extract the dell latitude 5590 share with me
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Post here lock bios
        • DProf.
          • Jun 2018
          • 100
          • Nigeria
          Thank u so much, and may ur wisdom continue to grow as time passes by.
          • medinfo
            • May 2016
            • 331
            • Morocco
            Latitude 5490 EC Bios plz
            I need EC bios for Dell Latitude 5490
            LA-F401P Rev 2.0
            UT6 = 2 Mb
            • mahmoodjavan
              Banned
              • Mar 2018
              • 584
              • iran
              Latitude 5490 LA-F401P ok
              • okbalord
                • Jun 2017
                • 205
                • Algeria
                need help DELL LATITUDE 5490
                HI I NEED BIOS DUMP FOR DELL LATITUDE 5490
                ddm70 la-f401p bios bin rev:3.0
                THANK U
                OKBALORD
                  • 22105
                  Re: need help DELL LATITUDE 5490
                  Use the forum search "la-f401p" , bios already posted for you to try .
                  • okbalord
                    • Jun 2017
                    • 205
                    • Algeria
                    thank you but i tried all the bios in the forum and the result is no display!!!
                    OKBALORD
                      • 22105
                      Post your original bios backup .
                      • okbalord
                        • Jun 2017
                        • 205
                        • Algeria
                        the problème that i do is that i dont make a backup i flacshed direct and clear the original tptally
                        OKBALORD
                        • foulou0238
                          • Mar 2014
                          • 109
                          • France
                          hello friend
                          try this one and let me know résult .
                          good luck
                          • okbalord
                            • Jun 2017
                            • 205
                            • Algeria
                            Originally posted by foulou0238
                            hello friend
                            good luck
                            TU BRO BUT NO POWER AT ALL
                            OKBALORD
                            • alas3376
                              • Nov 2011
                              • 382
                              • BENIN
                              Re: Latitude 5490 LA-F401P ok
                              Thank
                              • lpraderi
                                • Dec 2017
                                • 31
                                • Uruguay
                                need Bios and EC dump for Dell 5490
                                Hello, need Bios and EC dump for Dell 5490 (Compal LA-F401P rev. 3.0 / A02).
                                Thanks in advance.
                                • lapfix
                                  • Mar 2020
                                  • 2765
                                  • my workshop
                                  Re: need Bios and EC dump for Dell 5490
                                  Try this if not working post your old dump
                                  https://forum.laboneinside.com/viewtopic.php?t=7625
                                  • basic
                                    • Oct 2017
                                    • 229
                                    • 86357289244
                                    try this ..
                                      • 22105
                                      Originally posted by basic
                                      try this ..
                                      The bios is corrupt,its 12,288KB
                                      • bilen
                                        • Aug 2014
                                        • 637
                                        • istanbul
                                        Please clean me region la:F401P
                                        bios works but the first screen comes up in 30 seconds
                                        Can you fix this
                                        model : Dell Latitude 5490
                                        bios :
                                        • YOUCEF4787
                                          Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                          by YOUCEF4787
                                          I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                          Initial Problem:
                                          The laptop was completely dead, no signs of life, no power LED.
                                          Action Taken:
                                          I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                          Current Situation & The Main Issue:
                                          The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                          09-21-2025, 12:19 PM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                          DELL Latitude 5490 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5490 boardview and 5490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5490...
                                          09-06-2024, 12:36 PM
