Hello great engineers. Please I need bios dump for dell latitude 5490
dell latitude 5490 bios
Re: dell latitude 5490 bios
The latitude 5590,5490 and 5290 use the same bios . Check post #10 .https://www.badcaps.net/forum/showthread.php?t=67599 -
Pls if u have the password to extract the dell latitude 5590 share with meThe latitude 5590,5490 and 5290 use the same bios . Check post #10 .https://www.badcaps.net/forum/showthread.php?t=67599Comment
Thank u so much, and may ur wisdom continue to grow as time passes by.The latitude 5590,5490 and 5290 use the same bios . Check post #10 .https://www.badcaps.net/forum/showthread.php?t=67599Comment
Latitude 5490 LA-F401P ok
Latitude 5490 LA-F401P okAttached FilesPremium supporters get full download access and other benefits.
Re: need help DELL LATITUDE 5490
hello friend
try this one and let me know résult .
good luckAttached FilesPremium supporters get full download access and other benefits.
Re: need Bios and EC dump for Dell 5490
Try this if not working post your old dump
https://forum.laboneinside.com/viewtopic.php?t=7625Comment
try this ..Attached FilesPremium supporters get full download access and other benefits.
Please clean me region la:F401P
bios works but the first screen comes up in 30 seconds
Can you fix this
model : Dell Latitude 5490
bios :Attached FilesPremium supporters get full download access and other benefits.
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... -
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
This specification for the DELL Latitude 5490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5490 boardview and 5490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5490...09-06-2024, 12:36 PM
- Loading...
