macbook air 820-00165-a bios
  • skynet85
    • Jul 2015
    • 124
    • Georgia
    Re: 820-00165-a bios need
    Try
    • fiabo89
      • Nov 2019
      • 14
      • Italia
      Re: macbook air 820-00165-a bios
      thanks, tomorrow i'll try.
      • fiabo89
        • Nov 2019
        • 14
        • Italia
        thanks, worked perfectly <3
        • BrandonJL
          • Dec 2019
          • 18
          • South Africa
          A1466 Bios Cleanup ME
          I am working on a Apple MacBook Air A1466 820-00165-A logic board. The BIOS got corrupted or shorted because I have fan spin and all voltages are there, no chime or boot.
          The BIOS probably needs ME cleanup and serial change to C1MRTUDZH3QF. Please help...
          • DanielDacko
            • Mar 2015
            • 325
            • Macedonia
            Re: A1466 Bios Cleanup ME
            Here you go.
            I don't provide help for people using CH341A and a clip.
            • BadraYO
              • Oct 2016
              • 5
              • France
              #26
              hello, i have macbook air, fan spin and stops . please clean the ME, thanks
              • peste
                • Dec 2016
                • 12358
                • ROMANIA
                #27
                try...
                • lordmuken
                  • May 2018
                  • 52
                  • Philippines
                  #28
                  hello! can someone fix my BIOS? sometimes it will boot, but it take 2-3mins.
                  most of the time black screen, but the fan spin. when it boot the unit random shutdown.
                  done rebuilding the corroded bios area in the board.
                  • bigig
                    • Oct 2019
                    • 12
                    • st lucia
                    #29
                    can some please help me unlock this 2015 macbook air bios
                    • lordmuken
                      • May 2018
                      • 52
                      • Philippines
                      #30
                      Originally posted by peste
                      try...
                      This BIOS worked fine with the unit that im repairing.
                      can someone please change the Serial number into
                      FVFSN95CH3QD
                      • Mazorca
                        • Jan 2017
                        • 463
                        FVFSN95CH3QD
                        Here you go, with your serial number.
                        • lordmuken
                          • May 2018
                          • 52
                          • Philippines
                          #32
                          Thank you! The unit is now working
                          • Mazorca
                            • Jan 2017
                            • 463
                            I'm glad to be of help.
                            • peste
                              • Dec 2016
                              • 12358
                              • ROMANIA
                              #34
                              try..
                              • hazem3636
                                • Jun 2022
                                • 35
                                • sa
                                #35
                                A1466 820-00165-a
                                hi there
                                my issue is corrupted bin file and i want to get good bin file please with same Serial Number and with same Version please check the attached file
                                • hazem3636
                                  • Jun 2022
                                  • 35
                                  • sa
                                  #36
                                  The BIOS probably needs ME cleanup and serial change to FVFYQ6F2J1WK. Please help
                                  and attached version number and corrupted BIN file
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    The serial has not been changed, it is the same as serial you posted, CRC32 is valid, only cleaned out the ME Region. Report back if successful.
                                    • Kurl
                                      • Aug 2022
                                      • TX
                                      #38
                                      Can someone help me unlock A1466 macbook air bios (820-00165-A). Thank you
                                      • DanielDacko
                                        • Mar 2015
                                        • 325
                                        • Macedonia
                                        #39
                                        Here you go...
                                        • Kurl
                                          • Aug 2022
                                          • TX
                                          #40
                                          Originally posted by DanielDacko
                                          Here you go...
                                          Thank you
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
