warriors_amddis_mb_ddr3 16883-1 bios repair
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    i want this file to be repair.(warriors_amddis_mb_ddr3 16883-1}
    model=15-br068cl
    SN#=8CG7443N75
    I have attached the old dump
    • 21692
    Re: warriors_amddis_mb_ddr3 16883-1 bios repair
    Download and run the bios update exe ,select the copy option.There are 2 different bios versions.Search through your bios backup using a hex editor looking for both bios numbers, see the attached picture your bios is 08315. Next, use the hex editors search function to look for the serial number in your bios backup. See the attached picture for the DMI area , copy that to the new bios .
    https://ftp.hp.com/pub/softpaq/sp111...0/sp111600.exe
    HxD Hex Editor - https://mh-nexus.de/en/hxd/
    • jacospama
      • Aug 2019
      • 240
      • Ghana
      Thank you . but please how can i replace the dmi area i have copied to the new 08315 bin
      • peste
        • Dec 2016
        • 13451
        • ROMANIA
        (copy - paste) ... from the original bios, in update.
        • jacospama
          • Aug 2019
          • 240
          • Ghana
          Thank you Senior
          • TechMark1
            Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
            by TechMark1
            I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
            09-21-2025, 03:36 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • Caimano
            Need to copy DMI info for HP ProBook 650 G2 Bios
            by Caimano
            UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
            Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
            01-03-2024, 05:19 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
