Dell Latitude 5400 Bios password
  • selcuk
    replied
    shiyb
    thank you very much it works without any problems best regards
    commented on 's reply
    E7A8 suffix - https://www.badcaps.net/forum/troubl...23#post1622423
  • shiyab
    replied
    Originally posted by selcuk
    dell latitue 5400
    s tag : D0MXP13
    D0MXP13-E7A8
    hi try and feedback
  • selcuk
    replied
    dell latitue 5400
    s tag : D0MXP13
    D0MXP13-E7A8
  • shiyab
    replied
    CAN YOU HELP ME REMOVE THE PASSWORD?
    post snid
  • selcuk
    replied
    dell 5400 : S TAG : D0MXP13
    ŞİFREYİ KALDIRMAMA YARDIMCI OLABİLİR MİSİNİZ?
  • shiyab
    replied
    Originally posted by dhudz1968
    please help need to unlock
    EDC41 LA-G891P REV 1.0
    service tag:BJWDL33
    THANK YOU
    hi try
  • dhudz1968
    replied
    service tag:BJWDL33
    THANK YOU
  • moshu
    replied
    hi, is me again, last laptop is giving me headache. I am not able to READ or FLASH the 8MB chip, as the other ones. Is giving an error :
    Pin detected passed
    Check ID Error!
    Checked ID is : 0x FF FF FF
    Wish to continue programming, please cancel[Check Device ID] option!​
    I did disable "Check ID" and reading went through, but writing Didn't.
    Is there any solution for this issue?
    Chip is the same as for the other ones so is not possible to pick a wrong chip from the list
    Thanks in advance
  • moshu
    replied
    Originally posted by moshu
    I've read the 8MB chip on the the 2nd Laptop , but Rex patcher doesnt recognize. I've read the 16MB as well, went through the patcher and the same.
    Any idea what is wrong here?
    in the end I've write the same patch from the first computer to the 2nd and is working
  • moshu
    replied
    thanks, I've used the patch for the 8MB chip and initially computer restarted every 5 seconds Redo the soldering and is good now
    Thanks again
  • moshu
    replied
    Originally posted by Markus1741
    Now you can see how well the Rex98 software works.
    The 16MB Bios chip doesn't need to be patched because nothing is found in it.
    If you have 2 chips, as in your case, you have to consider which of the two should be processed.
    In your case only the 8MB chip needs to be written back.
    Thanks again
  • Markus1741
    replied
    I've try link above but doesn't want to generate the patch file for the 16M chip, it does for the 8M chip instead. Below is the error:
    Rex98 **Dell-8FC8-Patcher**
    @Tecshack Cebu
    Pag huwat ky ga patch pa!...in file W25Q128JV@SOIC8_61F0533_PSW_V2.BIN
    wa nakit-an ang intel signature
    Pinduta bisan unsang key para ma exit...
    Please help me understand what I have to do next.
    In the meantime if someone can patch both file for me
    Model: Dell Latitude 5400
    Board: EDC41LA-G891P
    REV: 1.0 (A00)
    SERVICE TAG: 61F05-8FC8
    In your case only the 8MB chip needs to be written back.​
  • moshu
    replied
    @Tecshack Cebu
    Pinduta bisan unsang key para ma exit...​
    REV: 1.0 (A00)
  • moshu
    replied
    Great, in the case of laptops with 2 BIOS chip I suppose I will have to patch both, I suppose
  • hoaca388
    replied
    Thanks Marcus,
    I will really want to learn how you did that, because I still have 11 laptops to fix (same model), some with 2 bios chips some with one.
    Is there a tutorial for beginners somewhere to follow?
    Last night I've been able to fix other 2 laptops testing some of the bin files already shared on this thread, and found 2 files compatible (Latitude E5400_256_CLEAN.rar & BACKUP_DELL LATITUDE 5400 EDC41 LA-G891P REV 1.0(A00) 2019-03-28.rar)
    https://www.badcaps.net/forum/troubl...s-out-for-free
  • moshu
    replied
    Hello try this unlocked file ....
    Thanks Marcus,
  • Markus1741
    replied
    please help to remove pasword on below 5400.
    I've tryed
    1- Select the range 00045000 to 00048fff
    2- Select "Edit" then "Fill"
    3- Put "ΓΏ" in "Pattern" zone.
    4- Choose "Fill selection" then clic on "Fill" button.
    5- Save the new file."
    but laptop didnt start
    Board: EDC41LA-G892P
    REV: 1.0 (A00)
    SERVICE TAG: 9QGW3Z2-8FC8
    read one CHIP GD25Q256DY1G
  • moshu
    replied
    I've tryed
    REV: 1.0 (A00)
    replied
    Originally posted by mactouch
    I need bios for la-g862p rev : 1.0 latitude 5400
    it is working but somebody changed before .
    only turning on after 30sec
    SN: 9CS6063
    Have you tried cleaning the ME firmware https://www.badcaps.net/forum/troubl...22#post1622422
  • jhanra
    by jhanra
    in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
    11-02-2024, 04:19 AM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
    DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
    09-06-2024, 12:13 PM
