Dell Latitude 5400 Bios password
  • volinakis
    • Jan 2021
    • 2743
    • N/A
    #781
    Originally posted by Haitazakaria
    This is the second bios
    try. Write only 16Mb chipset.
    • TAHAR AMAR
      • Jun 2025
      • ALGER
      #782
      BONJOUR
      DELL LATITUD 5400
      MODEL LA G891P
      SERVICE TAG 1WQ0433
      PROBLEM BIOS PASSWORD
      • shiyab
        • Sep 2023
        • 1503
        • india
        #783
        Originally posted by TAHAR AMAR
        BONJOUR
        DELL LATITUD 5400
        MODEL LA G891P
        SERVICE TAG 1WQ0433
        post backup bios
        • Ryeo
          • Jun 2022
          • Philippines
          #784
          Hello I already patch my bios I have Dell Latitude 5400 8fc8 the admin password has been removed but I couldn't install Operating System it either goes bluescreen or no bootable device. The usb bootable drive is detected and I can install the OS but after restart it goes BSOD
          • robert1000
            • Aug 2015
            Hello guys. I bought a Latitude 5400 from a site. I turn it on and it says "this computer is protected by a password authentication system".
            Can you help me remove this password? Besides the model number, S/T, board model, which of the two flash chips should i remove and read to post here the content? There are 2 bios chips on the board. Thank you!
            • Lover1abd
              • May 2023
              • 11
              DELL LATITUD 5400
              MODEL LA G891P
              SERVICE TAG C8SD433
              THANKSS
              • hoaca388
                Badcaps
                • Jan 2022
                • 11865
                #787
                Originally posted by Lover1abd
                DELL LATITUD 5400
                MODEL LA G891P
                SERVICE TAG C8SD433
                THANKSS
                3.4. Dell
                Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                Note: There is no publicly available 8FC8 generator available at the moment.
                The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                • shiyab
                  • Sep 2023
                  • 1503
                  • india
                  #788
                  DELL LATITUD 5400
                  MODEL LA G891P
                  SERVICE TAG C8SD433
                  THANKSS
                  hi try
                  • Stefan Steff
                    • Mar 2024
                    • 265
                    #789
                    DELL LATITUD 5400
                    MODEL LA G891P
                    SERVICE TAG C8SD433
                    THANKSS
                    At first boot press F2, write your Service Tag, disable Absolute if it was activated, Save and Exit.
                    • Lover1abd
                      • May 2023
                      • 11
                      Originally posted by hoaca388
                      3.4. Dell
                      Didn't work out
                      • Lover1abd
                        • May 2023
                        • 11
                        Originally posted by shiyab
                        hi try
                        After flashing no display
                        • Lover1abd
                          • May 2023
                          • 11
                          Only power light with no display
                          Could be chip went bad ????
                          • Lover1abd
                            • May 2023
                            • 11
                            3.4. Dell
                            Actually its does works
                            With dell patcher but i had to wipe the chip first
                            Thank you so much
                            And thanks for everybody for helping me
                            • Kinshir
                              • Jul 2025
                              #794
                              I tried to remove the BIOS password on my Dell Latitude 5400 using the patcher.
                              Got a the bios dump with the programmer
                              And unlocked it with the patcher
                              But now whether I upload the initial dump or the unlocked dump, when I connect the power, the front led is white, the power button and the keyboard lights up for 1-2 seconds, the fan also starts for 1-2 seconds and it keeps repeating.
                              Please help.
                              Service Tag: J9XQ433
                              Board: LA-G891P
                              Thank you very much!
                              • peste
                                • 12908
                                • ROMANIA
                                #795
                                Please help.
                                Board: LA-G891P
                                You copied the bios with errors.
                                The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                solder wires between the programmer and the bios chip..
                                .here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                • Kinshir
                                  • Jul 2025
                                  #796
                                  I understand, but since I copied the original BIOS with errors, after I unsolder it, what BIOS I should write on it?
                                  Can you help me with a suggestion?
                                  Thank you!
                                  • LBTT1121
                                    • Nov 2024
                                    • 590
                                    • Việt Nam
                                    #797
                                    Please help.
                                    Board: LA-G891P
                                    try and feedback
                                    • Kinshir
                                      • Jul 2025
                                      #798
                                      I wrote the BIOS on the chip using the WSON8 probe, verified it twice but still the same behavior.
                                      I don't have knowledge of soldering to try and unsolder it, but I suspect that I might have damaged the chip connections to the motherboard with the probe, hence I will try with a local service to have it checked.
                                      I'm attaching two pics of the BIOS chip for your opinion.
                                      Thank you very much for all the help.
                                      • Markus1741
                                        • Sep 2020
                                        • 846
                                        • N/A
                                        #799
                                        Hello you can try this new build bios from your corrupt original bios good luck ....
                                        • g_george_n
                                          • Aug 2025
                                          • romania
                                          #800
                                          Hello Everyone, I have 8 dell Latitude 5400 laptops, Example: SERVICE TAG(S/N): 9L7K5Y2
                                          MFG YR:2019
                                          20873528858
                                          EXPRESS SERVICE CODE.
                                          Beg Model/z: P98G
                                          Reg Type No.. P98G001, the question is, can I find someone to help me privately to find out the bios password? including telling me which bios reader to buy, I am willing to contribute with a donation to the forum. Thanks, George
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                            09-06-2024, 12:13 PM
