Dell Latitude 5400 Bios password
  • yomiyep707
    • May 2023
    • 5
    • Moldova
    #361
    Re: Dell Latitude 5400 Bios password
    Hello, unlock my bios please, i forget password
    Motherboard - EDC41 LA-G891P
    Serial Number - HCPT2Z2
    • aldopc
      • Jul 2017
      • 465
      • Chilito
      #362
      Ok try and comment.
      • yomiyep707
        • May 2023
        • 5
        • Moldova
        #363
        Originally posted by aldopc
        Ok try and comment.
        Thank you very much, everything works great!
        • jetblue
          • Jul 2018
          • 17
          • usa
          #364
          hi,i have a pickle here. i did many bios dump of 5400 lats and used the methods here to unlock them but this one i have will not allow me to dump. it has a 25b256DYIG smd bios
          and it halts every programmer i put it to. the ground seems to be the culprit or pin 4.
          i use direct wire soldered to the solder blobs then wire to the programmer.
          its a LA-G891P rev1.0 board with the 23VPXY2-8FC8
          is my bios chip fucked? it still turns on and allows me to get to setup.
          • aldopc
            • Jul 2017
            • 465
            • Chilito
            #365
            Hello, what programmer are you using?
            • jetblue
              • Jul 2018
              • 17
              • usa
              #366
              so far i used the common ch341 and the blue one v1.7 with voltage select. both freeze the neoprogrammer and the ch341 the moment i connect to usb. used the clip side then the headers. i disconnect the ground wire it unfreezes but then i cant read the chip.
              • aldopc
                • Jul 2017
                • 465
                • Chilito
                #367
                Did you desolder the chip from the board or are you reading it soldered? If so, you must remove it from the motherboard and read it out.
                • bestlaptop
                  • Mar 2020
                  • 5
                  • Ukraine
                  #368
                  Hi. 5400 pass locked. please
                  • jetblue
                    • Jul 2018
                    • 17
                    • usa
                    #369
                    i reinstalled the wires for a 4th time for some reason to see if i could try something diffrent and the ch431 acted normal and i was able to dump the firmware!
                    no idea what i did diffrent i suspect a witches spell for that day but thanks everyone.
                    • bestlaptop
                      • Mar 2020
                      • 5
                      • Ukraine
                      #370
                      It can be done much easier if you buy a probe on ali or other marketplace. just google "wson8 test probe".
                      • hieu13pro
                        • Jun 2023
                        • 29
                        • viet nam
                        #371
                        Hello. I have a BIOS file that is experiencing issues. My Dell computer is getting quite hot even though it has just started up Windows and opened one Chrome tab. Can you help me modify this BIOS file? Thank you. Dell 5400 LA-G891P REV 1.0
                        • hieu13pro
                          • Jun 2023
                          • 29
                          • viet nam
                          #372
                          La-g891p rev 1.0
                          svtag:8h573h2
                          thank you!!!
                          • lapfix
                            • Mar 2020
                            • 2719
                            • my workshop
                            #373
                            Originally posted by hieu13pro
                            La-g891p rev 1.0
                            svtag:8h573h2
                            thank you!!!
                            Bios password or computrace or no display !!
                            • hieu13pro
                              • Jun 2023
                              • 29
                              • viet nam
                              #374
                              My device is slow to boot up and becomes very hot quickly.
                              • lapfix
                                • Mar 2020
                                • 2719
                                • my workshop
                                #375
                                Try this clean me
                                • hieu13pro
                                  • Jun 2023
                                  • 29
                                  • viet nam
                                  #376
                                  The BIOS is functioning, but there is no fan detected, indicating a fan error.
                                  My computer gets hot after using it for a while like this. Can you help me? Thank you
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1224
                                    • France
                                    #377
                                    Originally posted by essaadi
                                    I found a solution to clear password from BIOS bin file (using "Hex Editor Neo"):
                                    1- Select the range 00045000 to 00048fff
                                    2- Select "Edit" then "Fill"
                                    3- Put "ÿ" in "Pattern" zone.
                                    4- Choose "Fill selection" then clic on "Fill" button.
                                    5- Save the new file.
                                    Enjoy!!
                                    NB : Always make copy of backup then work....
                                    Hello
                                    Need unlock 2 dell 5400 32Mo Bios
                                    I try this method on 2 Pc's, work well
                                    but not work on two another 5400
                                    • hardware1
                                      • Sep 2021
                                      • 2930
                                      • N/A
                                      #378
                                      Originally posted by Maxpower3
                                      Hello
                                      Here are your Unlocked files, I hope it works fine.
                                      In the first boot go to BIOS Menu, put your Service Tag, disable absolute (if it's enabled), save and exit. After that you can press ALT+F to exit MPM.
                                      Service Tag_1: 4YNG2Z2.
                                      Service Tag_2: HZKF2Z2.
                                      all donations are welcome,
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1224
                                        • France
                                        #379
                                        I try tomorrow
                                        just need 2 modifications here ?
                                        Perfect thanks
                                        • hardware1
                                          • Sep 2021
                                          • 2930
                                          • N/A
                                          #380
                                          I try tomorrow
                                          Perfect thanks
                                          You're welcome.
                                          Yes, I think this will erase the Password.
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                            09-06-2024, 12:13 PM
