lenovo t560 20fj help to try new bios
  • mgjini
    • Sep 2017
    • 199
    • united kingdom
    hi all
    i have got this lenovo t560 which for some reason i have tried many 2.5" ssds and the system doesn't recognise or work when i am trying to install fresh windows 10, i have even purchased new ssd to board cable connector and still same issue, but it i was to use hard drive 2.5" i am able to use and install fresh windows 10, i have tried many settings on my bios but still can not get to recognise ssd
    i am including here bios hopefully someone is able to give me some other bios so i can try, board is t560 type 20fj
    many thanks
  • peste
    • 13921
    • ROMANIA
    Re: lenovo t560 20fj help to try new bios
    Originally posted by mgjini
    hi all
    many thanks
    try..
    • mgjini
      • Sep 2017
      • 199
      • united kingdom
      Originally posted by peste
      try..
      hi Peste
      your bios is good, but i still have same problem ssd m.2 not detected, i am going to check further the board to see if i see anything
      many thanks for your help
      • mgjini
        • Sep 2017
        • 199
        • united kingdom
        just an update guys, for me the fuse on the board right next to the ssd / hdd connector was blown, replaced that and used a new ssd / hdd cable connector and now laptop is working, thanks all
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • grimacelord
          by grimacelord
          Hello there.
          History:
          03-15-2023, 03:29 PM
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
