lenovo t560 20fj help to try new bios
  • mgjini
    • Sep 2017
    • 199
    • united kingdom
    hi all
    i have got this lenovo t560 which for some reason i have tried many 2.5" ssds and the system doesn't recognise or work when i am trying to install fresh windows 10, i have even purchased new ssd to board cable connector and still same issue, but it i was to use hard drive 2.5" i am able to use and install fresh windows 10, i have tried many settings on my bios but still can not get to recognise ssd
    i am including here bios hopefully someone is able to give me some other bios so i can try, board is t560 type 20fj
    many thanks
  • peste
    • Dec 2016
    • 12742
    • ROMANIA
    Re: lenovo t560 20fj help to try new bios
    Originally posted by mgjini
    hi all
    many thanks
    try..
    • mgjini
      • Sep 2017
      • 199
      • united kingdom
      Originally posted by peste
      try..
      hi Peste
      your bios is good, but i still have same problem ssd m.2 not detected, i am going to check further the board to see if i see anything
      many thanks for your help
      • mgjini
        • Sep 2017
        • 199
        • united kingdom
        just an update guys, for me the fuse on the board right next to the ssd / hdd connector was blown, replaced that and used a new ssd / hdd cable connector and now laptop is working, thanks all
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • grimacelord
          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
          by grimacelord
          Hello there.
          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
          History:
          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
          I searched for this error online and discovered...
          03-15-2023, 03:29 PM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • mximiliandz
          help bios lenovo ideapad s145-14iil type 81w6
          by mximiliandz
          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
          06-20-2025, 06:50 AM
