Acer ES1-132 C30B bios password
  • yobbgsm
    • May 2017
    • 63
    Does flashing the bios of Acer ES1-132 removes the password? Unit has bios password so there is no way to do a reset on it's OS. Windows 10 has password too, resetting by doing Alt+F10 requires more space since it's just 32 emmc storage. I already done disconnecting the cmos battery and the battery itself for an hour but no go. It provides a password code after 3 hits but it does help either. Any thoughts?
    I have RT809F flasher.
    Thank you.
    • 20781
    Re: Acer ES1-132 C30B bios password
    try the acer 10 digit unlocker https://www.badcaps.net/forum/showthread.php?t=84084
    Edit: if that doesn`t work post your bios backup
    • yobbgsm
      • May 2017
      • 63
      Thank you sir. I tried to calculate the code 71802473 and the result is:
      f2fc129a0a428dbc
      But seems the character is limited in this model.
      I will back up the bios. Thank you for your help.
      • yobbgsm
        • May 2017
        • 63
        HI SMDFlea,
        This site code calculator looks great. My code works here and I was now able to access the bios.
        https://bios-pw.org/
        Thank you.
        • onizzbox
          Banned
          • Nov 2018
          • 604
          • Brazil
          f2fc129a0a428dbc
          Check the code 71802473, does it remain the same? Try the passwords below;
          Brand: Acer
          Code#: 71802473
          Unlock password (old): 64760475
          Unlock password (new): 38452015
          Unlock password (new): 38452016
          Type the unlock password and press <Enter>.
          • yobbgsm
            • May 2017
            • 63
            @onizzbox
            Thanks sir, I already unlock using the site above.
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • traxformania
              TONGFANG "GM7TG7P" Bios Password Problem?
              by traxformania
              I tried :
              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
              11-15-2023, 07:32 AM
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              Ack
              Ack
              01-30-2025, 04:26 AM
            • Nopslide
              by Nopslide
              04-01-2024, 04:27 PM
            • BlackVisor
              How to Decode BIOS password for RedmiBook Pro15 2022 6800H
              by BlackVisor
              RedmiBook Pro 1542022 6800H
              SKU: TM2113-39463
              Model Number: RMA2204-AB
              CMIIT ID: 2022AP1835
              SN: 39463/22WD01355
              BIOS version: RMARB5B0P1010 20230628
              1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
              2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
              3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
              01-14-2024, 06:35 AM
