lenovo miix 520-12IKB
Become a Badcaps supporter
Thanks to all supporters.
Re: lenovo miix 520-12IKB
Hello, please get me password for my Lenovo Miix 520-12IKB because i don't know password for bios. On Adress 00201000 is 23 12 1E 2F 12 31 02 32 FF FF FFAttached FilesLast edited by wfasyvsafv; 08-19-2022, 10:30 AM.Comment
@wfasyvsafv
This is the same password previously decoded, so I guess the last character is the checksum.
password = HEAVEN1M -> HEAVEN1
H - HOTEL ( UPPERCASE )
E - ECHO ( UPPERCASE )
A - ALFA ( UPPERCASE )
V - VICTOR ( UPPERCASE )
N - NOVEMBER ( UPPERCASE )
1 - 1 ( digit )
[M - MIKE ( UPPERCASE )]
--------Last edited by AAAC; 08-19-2022, 10:30 AM.Comment
Can you please help me decode password, bin file attached.
Thank youComment
Hi pal,
Just a little confused as to how to read this. So for example, the first 00 is 05 then 01 then 0B...you said number 30 would be for example the letter B but I'm not sure if I'm reading it right or not.
Can you explain a bit how to read/decode this? I've attached a screenshot.
Thank you,Comment
Hi pal,
Thank you,
----------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thanks for letting me know, can you tell me how to read it though, please?
Thanks!Comment
Thanks for letting me know, it works! But can you please teach me how to decode it?
What exactly do I need to do moving forward to read it myself, any help would be appreciated.
ThanksComment
This helped in decoding/translating, thank you:
https://www.win.tue.nl/~aeb/linux/kbd/scancodes-1.html
05 I'm assuming is the total number of characters
19 is P and 0B is 0(zero) 02 is 1(one) 31 is N and 14 is T.
Thanks again!Comment
@MrMike25, good luck!
password = OABPWD4W10
O - OSCAR ( UPPERCASE )
B - BRAVO ( UPPERCASE )
P - PAPA ( UPPERCASE )
W - WHISKY ( UPPERCASE )
D - DELTA ( UPPERCASE )
4 - 4 ( digit )
1 - 1 ( digit )
0 - zero ( digit )
--------Comment
@lextar
Open your BIOS file with UEFITOOL NE version, then on the BIOS Region on the 1st padding file, at Offset 1000h is the password stored as scancodes: first byte N specifies “password length”, then the next N bytes is the actual password (need to convert from scancodes to ASCII), the last byte is the checksum which is calculated as 8-bit addition of all (N+2) bytes, result must be 00h.
If it’s only Setup/BIOS that is locked, meaning that you can boot Windows, use a utility to read the BIOS without having to use a programmer.Comment
Yes, I can run windows, only the BIOS is locked.
I will attach here the BIOS with the password and try your procedure to extract the passwordAttached FilesComment
@lextar
At offset 1000h you will find this:
0723121E2F12310232h
password length = 07h
password (scancodes) = 23121E2F123102h
checkum (8-bit addition) = 32h
password = HEAVEN1
1 - 1 ( digit )
I remember seeing this same password before on posts #45 and #48.Last edited by AAAC; 10-27-2022, 11:01 AM.Comment
