HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
  • Mazorca
    • Jan 2017
    • 463
    I am having trouble decrypting the bios executable bin. I managed to get the bin but it is too big and nowhere looks like a bios. There are no identifing labels on the laptop bottom, I am taking my guess from the Bios dump and model on the touchscreen. Inside original bios are: C2M73UA#ABA and BID 01886.F12. Motherboard is labeled as LA-8551P and 700814-501. Symptoms are no video output, lighted keyboard keys (has backlight), keys beep when pressed, esc key does not, battery charging light is orange for a few seconds, turns white later. Mobo has onboard RAM chips, and uses DDR3L single RAM slot. Consumes ~35mA when connected to bench power supply, goes upt to 695mA when power button pressed. Video card chip gets hot, fan turns on after a few minutes.
    I have cleaned the ME region, same symptoms. Downloaded the BIOS executable from HP update, managed to extract a bin but I ran into trouble.
    Could someone either guide me, decrypt said bin or fix my bios dump, I would greatly appreciate it.
  • peste
    • Dec 2016
    • 13412
    • ROMANIA
    Re: HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
    bios extracted from the HP site update.
    • Mazorca
      • Jan 2017
      • 463
      Thank you peste, I still have no video on the touchscreen but I DO have video output on HDMI, so your bios works. I'm happy because finally after a couple of weeks I have something to work with. I'm going to check the touchscreen and LCD cable next. I did use the suggested tool (thank you to the mod), even ran it manually, but it gives me an error:
      C:\Users\Sergio\Downloads\phoenixtool273>hewprsa.exe -d 01886.bin -o 01886.DEC { -s 01886.SIG }
      Processing... This might take a few seconds.
      Header: BIOS_OFFSET:20[14] BIOS_SIZE:8388608[800000] BIOS_SIGN_SIZE:256[100]
      sizes do not match!
      10824:error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01:.\crypto\rsa\rsa_pk1.c:100:
      10824:error:04067072:rsa routines:RSA_EAY_PUBLIC_DECRYPT:padding check failed:.\crypto\rsa\rsa_eay.c:699:
      decipher failed: Permission denied
      ERROR: "No such device"
      What do you make of it? Look for an earlier date tool? I'm using the latest one.
      • peste
        • Dec 2016
        • 13412
        • ROMANIA
        sizes do not match!
        check the video chip ... it can be detached from the motherboard ... I didn't understand why you used Phoenixtool ...
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • al3m0di
          Update bios EFCN58WW to EFCN59WW
          by al3m0di
          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
          The BIOS version is EFCN58WW.
          When I turn on the device, it displays the message:
          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
          I've tried
          07-29-2024, 10:32 AM
        • 0xx
          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
          by 0xx
          Hi folks,
          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
          I assumed that Windows Update was interrupted due to closing...
          09-14-2025, 03:46 PM
        • trix11
          Dell Precision T1650 MT Workstation bricked after BIOS update
          by trix11
          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
          - Dell Precision T1650 mid tower Workstation
          - Xeon E3-1225 V2
          - 32Gb PC3-12800E RAM
          - 4Tb SATA HDD
          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
          I see now that others have experienced like issues e.g.:
          - https://www.dell.com/community/Prec...
          10-24-2022, 10:35 PM
