HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
  • Mazorca
    • Jan 2017
    • 463
    I am having trouble decrypting the bios executable bin. I managed to get the bin but it is too big and nowhere looks like a bios. There are no identifing labels on the laptop bottom, I am taking my guess from the Bios dump and model on the touchscreen. Inside original bios are: C2M73UA#ABA and BID 01886.F12. Motherboard is labeled as LA-8551P and 700814-501. Symptoms are no video output, lighted keyboard keys (has backlight), keys beep when pressed, esc key does not, battery charging light is orange for a few seconds, turns white later. Mobo has onboard RAM chips, and uses DDR3L single RAM slot. Consumes ~35mA when connected to bench power supply, goes upt to 695mA when power button pressed. Video card chip gets hot, fan turns on after a few minutes.
    I have cleaned the ME region, same symptoms. Downloaded the BIOS executable from HP update, managed to extract a bin but I ran into trouble.
    Could someone either guide me, decrypt said bin or fix my bios dump, I would greatly appreciate it.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
    bios extracted from the HP site update.
    • Mazorca
      • Jan 2017
      • 463
      Thank you peste, I still have no video on the touchscreen but I DO have video output on HDMI, so your bios works. I'm happy because finally after a couple of weeks I have something to work with. I'm going to check the touchscreen and LCD cable next. I did use the suggested tool (thank you to the mod), even ran it manually, but it gives me an error:
      C:\Users\Sergio\Downloads\phoenixtool273>hewprsa.exe -d 01886.bin -o 01886.DEC { -s 01886.SIG }
      Processing... This might take a few seconds.
      Header: BIOS_OFFSET:20[14] BIOS_SIZE:8388608[800000] BIOS_SIGN_SIZE:256[100]
      sizes do not match!
      10824:error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01:.\crypto\rsa\rsa_pk1.c:100:
      10824:error:04067072:rsa routines:RSA_EAY_PUBLIC_DECRYPT:padding check failed:.\crypto\rsa\rsa_eay.c:699:
      decipher failed: Permission denied
      ERROR: "No such device"
      What do you make of it? Look for an earlier date tool? I'm using the latest one.
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        sizes do not match!
        check the video chip ... it can be detached from the motherboard ... I didn't understand why you used Phoenixtool ...
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • al3m0di
          Update bios EFCN58WW to EFCN59WW
          by al3m0di
          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
          The BIOS version is EFCN58WW.
          When I turn on the device, it displays the message:
          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
          I've tried
          07-29-2024, 10:32 AM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • 0xx
          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
          by 0xx
          Hi folks,
          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
          I assumed that Windows Update was interrupted due to closing...
          09-14-2025, 03:46 PM
