HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
  • Mazorca
    • Jan 2017
    • 463
    I am having trouble decrypting the bios executable bin. I managed to get the bin but it is too big and nowhere looks like a bios. There are no identifing labels on the laptop bottom, I am taking my guess from the Bios dump and model on the touchscreen. Inside original bios are: C2M73UA#ABA and BID 01886.F12. Motherboard is labeled as LA-8551P and 700814-501. Symptoms are no video output, lighted keyboard keys (has backlight), keys beep when pressed, esc key does not, battery charging light is orange for a few seconds, turns white later. Mobo has onboard RAM chips, and uses DDR3L single RAM slot. Consumes ~35mA when connected to bench power supply, goes upt to 695mA when power button pressed. Video card chip gets hot, fan turns on after a few minutes.
    I have cleaned the ME region, same symptoms. Downloaded the BIOS executable from HP update, managed to extract a bin but I ran into trouble.
    Could someone either guide me, decrypt said bin or fix my bios dump, I would greatly appreciate it.
  • peste
    • 12959
    • ROMANIA
    Re: HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
    bios extracted from the HP site update.
    • Mazorca
      • Jan 2017
      • 463
      Thank you peste, I still have no video on the touchscreen but I DO have video output on HDMI, so your bios works. I'm happy because finally after a couple of weeks I have something to work with. I'm going to check the touchscreen and LCD cable next. I did use the suggested tool (thank you to the mod), even ran it manually, but it gives me an error:
      C:\Users\Sergio\Downloads\phoenixtool273>hewprsa.exe -d 01886.bin -o 01886.DEC { -s 01886.SIG }
      Processing... This might take a few seconds.
      Header: BIOS_OFFSET:20[14] BIOS_SIZE:8388608[800000] BIOS_SIGN_SIZE:256[100]
      sizes do not match!
      10824:error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01:.\crypto\rsa\rsa_pk1.c:100:
      10824:error:04067072:rsa routines:RSA_EAY_PUBLIC_DECRYPT:padding check failed:.\crypto\rsa\rsa_eay.c:699:
      decipher failed: Permission denied
      ERROR: "No such device"
      What do you make of it? Look for an earlier date tool? I'm using the latest one.
      • peste
        • 12959
        • ROMANIA
        sizes do not match!
        check the video chip ... it can be detached from the motherboard ... I didn't understand why you used Phoenixtool ...
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • al3m0di
          Update bios EFCN58WW to EFCN59WW
          by al3m0di
          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
          The BIOS version is EFCN58WW.
          When I turn on the device, it displays the message:
          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
          I've tried
          07-29-2024, 10:32 AM
        • trix11
          Dell Precision T1650 MT Workstation bricked after BIOS update
          by trix11
          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
          - Dell Precision T1650 mid tower Workstation
          - Xeon E3-1225 V2
          - 32Gb PC3-12800E RAM
          - 4Tb SATA HDD
          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
          I see now that others have experienced like issues e.g.:
          - https://www.dell.com/community/Prec...
          10-24-2022, 10:35 PM
        • Julian Bailey
          BIOS update wont complete - Dell Latitude 7420
          by Julian Bailey
          Hi all
          Anyone come across this issue where a BIOS flash will only part complete?
          It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
          NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
          The drive works fine in another laptop.
          Link to a video I made of what its doing here:
          Any ideas on how to overcome this?
          Cheers...
          06-02-2025, 01:39 PM
