Lenovo IdeaPad 3 15ADA05
  • Nicolas Tizzano
    • Apr 2024
    • 10
    • Argentina
    #181
    Originally posted by peste
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    Thanks peste for your answer!!
    I have one CH341 "pro", same as video... I was thinking to make a BackUp and wanted to compare with others just to see if it could be any difference and try to fix it...
    But i don't know if this is possible becouse differents hardware data or any code or key that is especific...
    First will do a backup... So, what can i do then?
    Could i try BIOS from #29?? but i need to put DMI info?? am i right? (i read all comments that day, i not remember correctly, sorry)...
    Huge hug for you!! Thanks for all!!
    • peste
      • 13924
      • ROMANIA
      #182
      post the backup copy here and we'll see..
      • Nicolas Tizzano
        • Apr 2024
        • 10
        • Argentina
        #183
        Hi! Thanks for your help!!
        Here is the files... I did not take chip out from board. I used a clip with 1.8v adapter. Looking in the datasheet it says 1.8v that is the W version of 25Q64JW
        Made 2 copys.
        Tell me if anything was wrong or right and how can i continue.
        Again, thanks for all your support!!
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          #184
          Made 2 copys.
          What is your serial number ?
          ​https://www.badcaps.net/donate
          • Nicolas Tizzano
            • Apr 2024
            • 10
            • Argentina
            #185
            I don`t know... there is no sticker anywhere... just a PartNumber inside moba: PN:5B20S44284...
            That's all!
            Thanks anyway! <3
            • peste
              • 13924
              • ROMANIA
              #186
              That's all!
              Thanks anyway! <3
              Look for a label on the laptop case.
              • borgesbe
                • Jan 2025
                • Portugal
                #187
                Hey there, have tried all BIOS on recommended posts, but still Ideapad3 15ADA05 has power blinking light with no image. SN is PF24W3TN, MTM 81W100EDPG, model name 81W1 and i did a bios dump before trying other versions. Can anyone point me in the right direction ?
                Badcaps Electronics Repair Forum & Schematic Search
                  • 22293
                  Please attach your backups directly to your post in a zip or rar.
                  • borgesbe
                    • Jan 2025
                    • Portugal
                    #189
                    Sorry SMDFlean, there it goes:
                    • peste
                      • 13924
                      • ROMANIA
                      #190
                      you have everything you need at post # 217..
                      https://www.badcaps.net/forum/troubl...11#post3237947
                      • borgesbe
                        • Jan 2025
                        • Portugal
                        #191
                        I'm sorry but i didn't follow...post 217 points to another user asking for correct bios, do you reffer to DMI copy ? from what i have been reading DMI doesn't male power led blinking but windows uefi key and other issues right ?
                        Edit: i think i got the problem, when i write BIOS and next when i read it results are the same. I am using clip and i think i will need 1.8v adapteur am i right ?
                        • peste
                          peste commented
                          Editing a comment
                          click on the link and see post #217..
                      • Nicolas Tizzano
                        • Apr 2024
                        • 10
                        • Argentina
                        #192
                        I'm sorry but i didn't follow... Soyo SY-7VBA133U points to another user asking for correct bios, do you reffer to DMI copy ? from what i have been reading DMI doesn't male power led blinking but windows uefi key and other issues right ?
                        If your chip is Winbond 25Q64JW you will need a 1.8v adapter, because W is for 1.8v chip...
                        I attach datasheet.
                        You have to see first which voltaje is working... may be chip could works with other voltages but better use the intended for. Even you can test 8 pin for seeing voltage from the board.
                        Hope could be helpful!
                        • Nicolas Tizzano
                          • Apr 2024
                          • 10
                          • Argentina
                          #193
                          Woow QR works and tell me wich computer ir... because there is no label just the ones in attached photo.
                          This computer is a IdeaPad 3 14ADA05 81W0 PN: PF2PRW41 MTM: 81W000MUAR
                          With AMD Ryzen 3 3250U and DDR4 4GB
                          Just for understand, why is important this numbers?? I really like to understand that... thanks for any kind of support!!
                          PD: my client was so awful taking care this computer... like you see in inside back plate.
                          • Nicolas Tizzano
                            • Apr 2024
                            • 10
                            • Argentina
                            #194
                            Just for refresh my problem...
                            The computer starts with Blue Screen Error... Client sends me a pic showing the Recovery instance with error code 0xc0000001
                            When I get it, i looked inside and saw that i was full of dirt. So i cleaned it.
                            Then I try turning on, and it allway get stuck "Loading Windows" in LENOVO Logo stage.
                            So i wanted to see BIOS, and pressing F2 or FN+F2, nothing happends, just LENOVO Logo without any loading, gettin stucked.
                            Looking for internet it says that this notebook comes with NOVO Button... i pushed it, Menú appear, but i have the same problem... BIOS is not working, just the LENOVO Logo. When I try another option, is the same... just goes to LENOVO Logo and get stucked there.
                            When I take off SSD m.2 the computer says:
                            "Verifiying shim SBAT data failed: Security Policy Violation
                            Somthing has gone seriusly wrong: SBAT self-check failed: Security Policy Violation"
                            So I realise that there is SecureBoot ON.
                            So... i could never go to BIOS... thats why i think there is a problem and wanted to test with another BIOS.... I don't know if there is any keyboard combination to Activate something which let me in BIOS.
                            I don't think that another thing is wrong... even i can't take out RAM couse they are SMD and soldered.
                            Thanks anyone for your help!! I hope this case could help others!
                            Namaste!
                            • izaak94
                              • Mar 2019
                              • 140
                              • mexico
                              #195
                              try..
                              Hello, could you help me extract the EC.... I tried with this copy but it didn't work, my equipment came with a wet EC and it was replaced, I don't have the serial number labels.
                              • volinakis
                                • Jan 2021
                                • 2877
                                • N/A
                                #196
                                Namaste!
                                there is a hole on the side of laptop, pressing on the switch inside that hole you'll be able to enter in bios setup, take from there serial no
                                • Nicolas Tizzano
                                  • Apr 2024
                                  • 10
                                  • Argentina
                                  #197
                                  Hi Volinakis, thanks for your help.
                                  I already try that, even i explain all in post 194
                                  All serial numbers that i have is from the webpage wich sends me the QR code from laptop label. Pictures attached in post 193
                                  The NOVO button that you means does not work, when I select BIOS option, it does not get in BIOS, just go ahead loading OS, and stuck there.
                                  I will try with another M.2 SSD just to see what's happening...
                                  • newarcada_computers@yahoo
                                    • Jan 2019
                                    • 37
                                    #198
                                    is working thanks
                                    • EpicFix
                                      • Aug 2024
                                      • 43
                                      • Trinidad & Tobago
                                      #199
                                      Hi, I need a BIOS file for Lenovo 15ADA05. The machine turns on without video, there is fan spin all voltages are present (3.3v, 5v, 19v) and the power button LED keeps flashing. It powered on once and gave TPM error message. I've tried the Novo button and disconnected CMOS to reset but to no avail. I suspect the issue is the on board RAM so if anyone can also provide me with a BIOS that has the on-board RAM disabled for troubleshooting as well I will also be gladly appreciative. Attached is a dump I was able to pull off the BIOS as required. Thanks in advance.
                                      IdeaPad 3 15ADA05.
                                      PN: 5B20S44266 (Not sure if this is the board serial number but this is what I got from the sticker on the RAM slot)
                                      Model: GS550
                                      • peste
                                        peste commented
                                        Editing a comment
                                        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                    • peste
                                      • 13924
                                      • ROMANIA
                                      #200
                                      IdeaPad 3 15ADA05.
                                      Model: GS550
                                      try post#217..
                                        Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 05:00 AM
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
                                      • joven016
                                        Lenovo Ideapad S145 need working bios HELP!!
                                        by joven016
                                        Problem is blinking power led only
                                        i don't know exactly if it's s145-15igm or s145-14igm
                                        have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                        Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                        Already tested some of posted bios here
                                        S145-14igm - success but invalid serial and not booting on OS
                                        S145-15igm - success with serial and some other info in bios but still not booting on OS
                                        already tried installing new windows but always booting on bios setup
                                        windows installer flash drive detected on...
                                        08-21-2025, 10:55 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • mximiliandz
                                        help bios lenovo ideapad s145-14iil type 81w6
                                        by mximiliandz
                                        Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                        06-20-2025, 06:50 AM
