Lenovo IdeaPad 3 15ADA05
  • Nielsm
    • May 2021
    • 6
    • Denmark
    #221
    Originally posted by RiderXO
    Weird, i tried a second time, with the same file and now i got error at address 4ABh
    RiderXO Yesterday when I flashed my Lenovo Flex 5 14ACL05 with a Winbond W74M12JW bios chip with a EZP2019 I had to do the following:
    - use a 1.8 V adapter
    - manually choose the most identical chip id as the EZP2019 wrongfully detected the bios chip as 93_EEPROM, ATMEL, AT93C46@16.
    I went with SPI_FLASH, Winbond, W25Q128JV, (1.8v)​
    - double verification of reading bios with 3 Mhz setting as higher fx 12 Mhz did not produce the same data each time.
    - Erase bios before writing then verifying bios data (Lesson Identified: if you only write - verify it's gonna produce an error).
    ie. did you erase before writing ?
    • peste
      • 13924
      • ROMANIA
      #222
      The bios chip must be unsoldered from the board before writing or reading..
      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
      solder wires between the programmer and the bios chip..
      here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHow​
      • RiderXO
        • Apr 2025
        • 6
        #223
        Yes i did erase the chip every time. EZ detects mine as W25Q64FW(1.8V). by default. And yes, i am using an adapter for 1.8v. If i search in EZ programmer database there is no 25Q64JWSIQ
        here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
        Hmm, yeah i am using the clip. Would a normal heat gun work?
        Here is a photo of my chip:
        • stjopa
          • Nov 2017
          • Hungary
          #224
          Hello! I would like to ask for help because I am completely stuck with this machine. The battery on the machine ran out during the update and since then only the power button LED has been blinking. I have tried several BIOSes from the site. With the factory e8cn36ww.bin, the Lenovo logo came up once, but never again. I would like help in creating a clean BIOS. I have attached the original BIOS dump. Thank you for your help!​
          Machine type: Lenovo Ideapad 3 15ADA05 (81W1)
          Serial number: PF29E61X
          • stjopa
            • Nov 2017
            • Hungary
            #225
            Thank you, no need to reply. After I wrote, I saw the link to extract the BIOS and copy the DMI. I successfully completed the steps and the laptop came to life. Have a nice day!
            • RiderXO
              • Apr 2025
              • 6
              #226
              i'm out of ideas...I unsoldered the chip from the MB, i put in the 1.8v adapter, the programmer read it as 3_EEPROM, ATMEL, AT93C46@16. I selected SPI-FLASH, Winbond W25Q64FW (1.8v) as this is the only chip with 8MB and 1.8 v , did a read test but it gave error chip not empty but i performed anyway erase-write-verify but at verify it still says error on some address...The only thing different then with the clip it was it took a whole lot longer to erase and write.
              Noob question, is it possible i am not aligning correctly the chip with pin 1 (the round small circle on the chip indicates which one is pin 1) on the programmer and still read it but in a wrong way? Or if i do not place the chip correctly on the programmer it won;t detect it at all?
              • RiderXO
                • Apr 2025
                • 6
                #227
                Haha. i did it. the chip reader was in the wrong place on the adaptor. I looked again to some tutorials and i aligned it ok then as soon as i pressed on the detect button it recognize it as W25Q64FW. Did erase-write-verify, with no error on verify. Soldered it back and the laptop was alive once again
                • csanad
                  • Oct 2021
                  • 6
                  • romania
                  #228
                  Hello friends,
                  Please help me, I need a BIOS for my Ideapad3 15 ADA05 81W1 laptop.
                  After a win10 update it won't start. The LEDs light up, the fan spins, the keyboard doesn't work and the screen doesn't turn on either.
                  I couldn't save the original BIOS. I loaded the BIOS posted an this forum by tracker1 but it doesn't work. Please, if you can help me with a working bios.
                  Motherboard NM-C821 Rev 1.0,
                  Processor Ryzen 7 3700u
                  BIOS original E8CN41WW,
                  SN: PF2C18LH.
                  Thank you,​
                  • peste
                    peste commented
                    Editing a comment
                    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                • Bios Cracker
                  • Oct 2024
                  • 324
                  • India
                  #229
                  Originally posted by csanad
                  Hello friends,
                  SN: PF2C18LH.
                  Thank you,​
                  send your original dump file.
                  • csanad
                    • Oct 2021
                    • 6
                    • romania
                    #230
                    The original dump file is compromised in my opinion. I checked it with a hex editor and most of it is with FF.​
                    • peste
                      • 13924
                      • ROMANIA
                      #231
                      • csanad
                        • Oct 2021
                        • 6
                        • romania
                        #232
                        I've done something like this before, but I don't know why the information wasn't read correctly, or that's how the information was, I don't know. Now, the deed is done, I have nothing to do, maybe someone can help me with a suitable dump. I've never had anything like this before, I've previously solved problems with BIOS and firmware on TVs and coffee makers. The programmer I worked with is EZP2019+, in my opinion it's no better than CH341A.
                        • csanad
                          • Oct 2021
                          • 6
                          • romania
                          #233
                          I tried 2 dumps: e8cn41ww and NM-C821 DUMP obtained from this site but without success. The laptop behaves the same with both.
                          The only option left was to try a virgin BIOS dump, also downloaded from this site. However, I can't try many dumps, as I can damage the board or chip by successive soldering and unsoldering.
                          • peste
                            • 13924
                            • ROMANIA
                            #234
                            you have everything you need at post #204...
                            https://www.badcaps.net/forum/troubl...da-bios/page11
                            • Jeyson
                              • Jul 2024
                              • 12
                              • ECUADOR
                              #235
                              Hola a todos, me podrían ayudar deshabilitando la memoria integrada. la misma me está provocando conflictos. Muchas gracias de antemano.
                              Hello everyone, could you help me by disabling the onboard memory? It's causing problems. Thank you very much in advance.
                              in English please..
                              • peste
                                • 13924
                                • ROMANIA
                                #236
                                in English please..
                                post S/N, full name and model, motherboard model, TYPE,etc.
                                • Jeyson
                                  • Jul 2024
                                  • 12
                                  • ECUADOR
                                  #237
                                  Lenovo Ideapad 3 14ada05
                                  S/N: PF19Q2HK
                                  Model: 81W0
                                  Thanks.
                                • yorossi
                                  • Jul 2024
                                  • 6
                                  Hello All ,
                                  Can someone help me with a working bios for my IdeaPad 3 17ADA05
                                  Motherboard : nm-c821 rev 1.0
                                  Model Name : 81W2
                                  SN:PF2S7JZR
                                  Thank you in advance
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12441
                                    #239
                                    Originally posted by yorossi
                                    Hello All ,
                                    Model Name : 81W2
                                    SN:PF2S7JZR
                                    Fault backup.
                                    • yorossi
                                      • Jul 2024
                                      • 6
                                      I am using a cheap CH341A programmer, and I do not have any backup. Do I have any chance to bring the laptop back to life again?
                                        Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 05:00 AM
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
                                      • joven016
                                        Lenovo Ideapad S145 need working bios HELP!!
                                        by joven016
                                        Problem is blinking power led only
                                        i don't know exactly if it's s145-15igm or s145-14igm
                                        have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                        Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                        Already tested some of posted bios here
                                        S145-14igm - success but invalid serial and not booting on OS
                                        S145-15igm - success with serial and some other info in bios but still not booting on OS
                                        already tried installing new windows but always booting on bios setup
                                        windows installer flash drive detected on...
                                        08-21-2025, 10:55 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • mximiliandz
                                        help bios lenovo ideapad s145-14iil type 81w6
                                        by mximiliandz
                                        Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                        06-20-2025, 06:50 AM
