HP Elitebook 850 G4 bios dump
  • alext28
    • May 2020
    • 51
    Hello guys , i need clean bios dump (without serial please) for 850 G4
    I have a few of these with this problem so it would be appreciated.
    thanks all
    i send a exemple (with bios password)
  • peste
    • 13600
    • ROMANIA
    Re: HP Elitebook 850 G4 bios dump
    thanks all
    try..
    • alext28
      • May 2020
      • 51
      Originally posted by peste
      try..
      work fine !
      thanks Peste , you ROCK !
      • rubenfix
        • Mar 2021
        • 12
        • spain
        hey ... I have an 840 g4, and it doesn't give me a picture, it turns on and turns on again, I think it's the bios .... I'll leave you here the bios .. I hope to help me, ...
        I tried the above but it does not give me an image, it turns on but after it turns off again and so on ...
        Thanks for the help!!
        • rubenfix
          • Mar 2021
          • 12
          • spain
          I have the problem that it does not work, that is, the fan is going full, and it does not give video .... ram memory ok ...
          surely the bios is ..
          I have the original dump ..
          I have the 850 g4
          • rubenfix
            • Mar 2021
            • 12
            • spain
            dump 16 mb 850 g4 recovry
            • peste
              • 13600
              • ROMANIA
              try..
              • rubenfix
                • Mar 2021
                • 12
                • spain
                try..
                It does not work, the same does not give an image and it restarts and turns on... any other solution?
                • mazoot
                  iFixit
                  • Jan 2019
                  • 41
                  • Moldova
                  try bro
                  Kill the state in yourself and you will be free like a wind...
                  • rubenfix
                    • Mar 2021
                    • 12
                    • spain
                    Originally posted by mazoot
                    try bro
                    the same, as the previous one .. without image and restarts ...
                    • peste
                      • 13600
                      • ROMANIA
                      if you have tried three, four different bios and the defect is the same, you may have another problem.
                      • rubenfix
                        • Mar 2021
                        • 12
                        • spain
                        this is my 850 g4 motherboard ... 6050A2854301-MB-A01 850 G4,,, I don't think I have another problem ...
                        • peste
                          • 13600
                          • ROMANIA
                          rty..
                          • rubenfix
                            • Mar 2021
                            • 12
                            • spain
                            rty..
                            Not work ... Thanks for help ,
                            • sellit
                              • Jun 2017
                              • 105
                              • Latvia
                              Can you fix my BIOS.
                              Symptoms: blinking CAPSLOCK and power button on and off after few seconds.
                              Tried with Intel Easy Clean Me, but still no picture.
                              • sellit
                                • Jun 2017
                                • 105
                                • Latvia
                                Anyone please!
                                • sellit
                                  • Jun 2017
                                  • 105
                                  • Latvia
                                  it is fixed, got the main BIOS dump from other thread.
                                    • 21907
                                    I wouldn`t use Intel Easy Clean Me ,you make things worse using that tool.
                                    • Ferimonka
                                      • Nov 2019
                                      • 40
                                      Hi Guys, Kindly ask for a password remove from the bios dump attached. Many thanks.
                                        • 21907
                                        Try RCUnlocker https://www.badcaps.net/forum/showthread.php?t=103526
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
