HP Elitebook 850 G4 bios dump
  • alext28
    • May 2020
    • 47
    Hello guys , i need clean bios dump (without serial please) for 850 G4
    I have a few of these with this problem so it would be appreciated.
    thanks all
    i send a exemple (with bios password)
  • peste
    • 12734
    • ROMANIA
    Re: HP Elitebook 850 G4 bios dump
    thanks all
    try..
    • alext28
      • May 2020
      • 47
      Originally posted by peste
      try..
      work fine !
      thanks Peste , you ROCK !
      • rubenfix
        • Mar 2021
        • 12
        • spain
        hey ... I have an 840 g4, and it doesn't give me a picture, it turns on and turns on again, I think it's the bios .... I'll leave you here the bios .. I hope to help me, ...
        I tried the above but it does not give me an image, it turns on but after it turns off again and so on ...
        Thanks for the help!!
        • rubenfix
          • Mar 2021
          • 12
          • spain
          I have the problem that it does not work, that is, the fan is going full, and it does not give video .... ram memory ok ...
          surely the bios is ..
          I have the original dump ..
          I have the 850 g4
          • rubenfix
            • Mar 2021
            • 12
            • spain
            dump 16 mb 850 g4 recovry
            • peste
              • 12734
              • ROMANIA
              try..
              • rubenfix
                • Mar 2021
                • 12
                • spain
                try..
                It does not work, the same does not give an image and it restarts and turns on... any other solution?
                • mazoot
                  iFixit
                  • Jan 2019
                  • 41
                  • Moldova
                  try bro
                  Kill the state in yourself and you will be free like a wind...
                  • rubenfix
                    • Mar 2021
                    • 12
                    • spain
                    Originally posted by mazoot
                    try bro
                    the same, as the previous one .. without image and restarts ...
                    • peste
                      • 12734
                      • ROMANIA
                      if you have tried three, four different bios and the defect is the same, you may have another problem.
                      • rubenfix
                        • Mar 2021
                        • 12
                        • spain
                        this is my 850 g4 motherboard ... 6050A2854301-MB-A01 850 G4,,, I don't think I have another problem ...
                        • peste
                          • 12734
                          • ROMANIA
                          rty..
                          • rubenfix
                            • Mar 2021
                            • 12
                            • spain
                            rty..
                            Not work ... Thanks for help ,
                            • sellit
                              • Jun 2017
                              • 104
                              • Latvia
                              Can you fix my BIOS.
                              Symptoms: blinking CAPSLOCK and power button on and off after few seconds.
                              Tried with Intel Easy Clean Me, but still no picture.
                              • sellit
                                • Jun 2017
                                • 104
                                • Latvia
                                Anyone please!
                                • sellit
                                  • Jun 2017
                                  • 104
                                  • Latvia
                                  it is fixed, got the main BIOS dump from other thread.
                                    • 20784
                                    I wouldn`t use Intel Easy Clean Me ,you make things worse using that tool.
                                    • Ferimonka
                                      • Nov 2019
                                      • 40
                                      Hi Guys, Kindly ask for a password remove from the bios dump attached. Many thanks.
                                        • 20784
                                        Try RCUnlocker https://www.badcaps.net/forum/showthread.php?t=103526
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • mediadoctor
                                          Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
                                          by mediadoctor
                                          Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
                                          07-20-2025, 09:38 AM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          Yesterday, 07:11 AM
